Old 03-12-2017, 02:11 PM   #1
ebaby35
Stepside hanger install issue
I bought two hangers for my step and i can see where it bolts to the actual step but cant find where tha back of the bracket bolts to there is open space with nothing to bolt to. Is there anyway that the front panel is from from year and too small. Does anyone know what the measurement should be
ebaby35 is offline   Reply With Quote
Old 03-12-2017, 05:24 PM   #2
step65
Re: Stepside hanger install issue
I believe they bolt to the cross sill under the bed. Bolt it to the step and hold it up to bed you should be able to see where it goes from there.
step65 is offline   Reply With Quote
Old 03-15-2017, 01:42 AM   #3
ebaby35
I checked out my friends c10 and yes it does bolt to to the cross sill between the brace. I'll have to post a pic of mine because it's coming up short from the bracket.
Old 03-17-2017, 01:30 AM   #4
ebaby35
Ok I cant figure out for the life of me what's wrong. The hanger should go between cross sill but doesn't line up and seem to be alittle short. I can only slide back alittle not sure if that will help. And maybe the angle bracket on side panels was messed with and put too low. Any help would be great.
Old 03-17-2017, 10:18 AM   #5
slorio
slorio's Avatar
ebaby:
Should be two holes like this in the end of your two cross braces closest to the cab. The bracket you are holding bolts between the cross brace in its open U shape with the bolts going through these two holes into the threads in your bracket.
Hope that helps. See attached for holes.
Regards,
Steve
slorio is offline   Reply With Quote
Old 03-17-2017, 10:55 PM   #6
ebaby35
I had to buy new cross sill and got them from classic industries they didn't come with the holes
Originally Posted by slorio View Post
ebaby:
Regards,
Steve
Old 03-18-2017, 09:46 PM   #7
slorio
slorio's Avatar
Ebaby:
I saw that your sills were new and feared that was the case. Nice of them to leave that detail out...
Hope the pictures help. Please let me know if you need some type of measurement.
regards,
Steve
New Orleans
Old 03-25-2017, 07:29 PM   #8
ebaby35
My hanger has two holes that can be screwed down to the cross sill. Are both those holes use or is only one needed? Because if both are supposed to be attached something is wrong because only one goes into the cross sill deep enough
Old 03-26-2017, 08:35 AM   #9
slorio
slorio's Avatar
Ebaby:
Should be using two 5/16" holes for each bracket to mount hangars. Please let me see a picture of what you are doing and I can advise better from there.
regards,
Steve
New Orleans
Old 03-26-2017, 10:05 AM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
I had to drill mine in place. lifted the front end of the bed up and did some serious measuring and drilled. Got the passenger side dead on. The driver side, not so much. But got them installed before I sent them to paint shop.
Old 03-26-2017, 02:23 PM   #11
RLag
These pics show the orientation and approximate hole pattern. Holes are 3/8" for 5/16" bolts.
Drilled braces would have holes on only one side so maybe recheck all of your braces for holes.
Hope this helps!
Randall
Houma, LA
RLag is offline   Reply With Quote
Old 04-17-2017, 04:55 PM   #12
Jocko87
Where were you able to buy the braces themselves from?
Jocko87 is offline   Reply With Quote
Old 04-17-2017, 08:17 PM   #13
RLag
LMC carries the step and cross braces and MAR-K also has the cross braces and other bed parts. I have pieces from both that fit well.
Old 04-18-2017, 04:25 PM   #14
forestb
forestb's Avatar
That hole should be lined up with the hole in the cross sill. It looks like your entire bed needs to move forward.
forestb is offline   Reply With Quote
Old 04-24-2017, 05:32 PM   #15
Jocko87
LMC doesn't have the step braces that I or the nice lady one the phone could tell. I found some on Ebay that are a little iffy, I'd prefer a vendor.
Old 04-24-2017, 07:36 PM   #16
RLag
Sorry, I thought you were looking for the "step hanger" or maybe "cross sill" (pages 18-19 on LMC 60-66 chevy truck) but if you talk about the stepside "fender brace rod" I also had trouble finding them from a source other than ebay. These rods are listed on the Goodmark Industries site as: 1965 Chevrolet C10 Pickup REAR STEPSIDE FENDER BRACE SET, 55-66 STEPSIDE PICKUP (3 PIECE SET FOR ONE SIDE) - 4141-662-55S
Hope this helps,
RL
Old 04-24-2017, 09:00 PM   #17
The Rocknrod
Moderator
I made the brace for the step (attaches thru the frame) out of a set of fender braces. Just cut shaped and threaded them. Worked well. In fact someone on this board gave me that idea.
