Old 01-26-2017, 10:10 AM   #451
duallyjams
duallyjams's Avatar
Re: 67 GMC super custom build
vote red
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-26-2017, 10:16 AM   #452
saskman02
I'd vote red but only if the texture of the remaining column can be matched. If not, then chrome.
1967 C10 SWB Small Window
saskman02 is offline   Reply With Quote
Old 01-27-2017, 01:29 PM   #453
chewychevy67
The more I think about it I think chrome would hide the shift gear selector and I want to accent that so red it is.
chewychevy67 is offline   Reply With Quote
Old 02-06-2017, 03:01 AM   #454
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-17-2017, 02:31 PM   #455
chewychevy67
Got my radio back from restoration. Here is a video. It is cool. https://youtu.be/BQVudyOuO5c
Old 03-17-2017, 03:31 PM   #456
saskman02
Very cool! I like how the red needle disappears off the right side and reappears again on the far left. And nothing like listening to some old Dirt Band on 8-track!
What volume & selector knobs on the radio are you going to go with...the ones in the video or how they are shown a few posts back? The ones in the video look to me to be from a '80s GM radio.
Old 03-17-2017, 04:06 PM   #457
chewychevy67
I'm using the originals these are just what I had on the bench to test it. I want this truck to look stock with all these mods that most except purists would not even notice.
Old 03-17-2017, 07:21 PM   #458
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Enjoyed the video. That's a great addition to your build. Who did the radio resto?
Old 03-17-2017, 09:41 PM   #459
chewychevy67
Greg from electro tech. I am very happy with it
Old 03-21-2017, 06:18 PM   #460
chewychevy67
I got a dealer accessory from era Pontiac. It's called instant aire. It uses manifold vacuum pump up tires and such. The pump sits under the seat till you need it. Then just hook it up to the valve and you have compressed air.
Old 03-31-2017, 11:55 AM   #461
chewychevy67
Got one of these 60's reel out lights for under the hood as well. I do plan on driving this when I'm done so you never know when you will need a light.
Old 03-31-2017, 12:16 PM   #462
chewychevy67
I was really torn between drums and discs but my dad said don't be silly son you added everything available era related so put discs on and be done with it. When your doing your brake maintenance you will be thankful. So they showed up today too!
Old 04-02-2017, 02:28 PM   #463
chewychevy67
My mcgaughys disc kit not only didn't come with dust shields it didn't come drill or tapped to mount them. I got some from a 72 and I tapped the holes to mount them. I thought it was a little crappy for those not to be tapped for the price you pay.
Old 04-04-2017, 10:21 AM   #464
chewychevy67
Denis at http://qualityrestorations.com/?no_redirect=true sent me a photo of my re-casted steering wheel. Looks sweet. He is shipping it today.
Old 04-09-2017, 05:00 PM   #465
chewychevy67
I bought a new master cylinder for disc drum but all the new M/C didnt have the residual valve in the rear drum side of the M/C so I removed mine from my original and installed it into my new one. It is the rubber and spring that goes behind the brass head that seats to the line flare. If it was there from factory I believe it was there for a reason.
Old 04-09-2017, 10:52 PM   #466
chewychevy67
Also added a disc brake button to my pedal like the 60's era gm cars used.
Old 04-10-2017, 10:13 AM   #467
Hart_Rod
Hart_Rod's Avatar
I think dodge had optional passenger seat sliders on their truck buckets. I bought them from ledzepp so maby contact him for more info as I am not 100% sure. Will sure make jack accesability much easier.
Didn't realize dodge offered a slider for the passenger seat. I've been trying to convert my Chevy slider to the passenger side without much luck. Hopefully I can track one of these down....
Hart_Rod is offline   Reply With Quote
Old 04-10-2017, 11:43 AM   #468
Hart_Rod
Hart_Rod's Avatar
Here is the tool box I pick up close to home. It will need some work but that's ok.
If you do the tool box door, I bet if you give Mar-K.com a call, they will work with you on building some custom trim. Also, just noticed you didn't use the dodge passenger side seat tracks. Do you still have them?
Old 04-10-2017, 11:51 AM   #469
chewychevy67
No I sold them.
Old 04-11-2017, 07:35 PM   #470
chewychevy67
I already had all my original 67 brake lines finished and really did not want to put new ones on again for the disc brakes so I did some research. Here is what I came up with. In 1967-70 chevy cars used separate metering, proportioning valve and distribution blocks and in 1971 went to a combination valve with all 3 of these in it. I decided to go the early 67-70 car route . The proportioning valve is on the frame and the metering and distribution block are next to the master cylinder.
Old 04-11-2017, 10:02 PM   #471
Pancho_peso
Pancho_peso's Avatar
Got the gmc logo thermometer face. Can't believe how accurate this is. I wonder if it reads the same when your driving?
What kind of vehicle did this come out of
Pancho_peso is offline   Reply With Quote
Old 04-11-2017, 10:49 PM   #472
chewychevy67
It is the system GM Used on disc brake cars, not just Camaro's, from 1967 to 1970. Here is more info on it. http://www.camaros.org/brakevalve.shtml
Old 04-12-2017, 12:39 AM   #473
chewychevy67
The thermometer is from 74 to 78 gmc trucks I believe. Definitely from the square bodies.
Old 04-14-2017, 10:01 PM   #474
chewychevy67
Got this overdrive cable from a chevy 3 speed standard transmission with over drive. If I choose to do a gear vendors overdrive I will incorporate it to work so it looks vintage.
Old 04-15-2017, 11:08 PM   #475
chewychevy67
I added one of TBONE 1964's volt gauge conversions to my cluster tonight.
