Too close to the steering wheel
I've put different seats in my '68 and I can't get far enough away from the steering wheel. I don't need a whole lot, but I need a little room. What are my choices?
Re: Too close to the steering wheel
You can shorten the column by collapsing the sleeve in the lower portion near the rag joint. I recently did mine 2" and it makes a world of difference to me. You can find good info in these threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=191143 http://67-72chevytrucks.com/vboard/s...d.php?t=309895 http://67-72chevytrucks.com/vboard/s...olumn+collapse |
Thanks, Ben! I may be be using that trick after I get the steering wheel swapped.
I found Tilt helped a great deal, but I was just trying to get the wheel out of may lap, not out of my belly, so I don't know if tipping up and away would benefit you. But it might, and it's a pretty easy thing to find and add.
Worth trying it in someone else's tilt truck if you can. The column shortening looks perfect, but I worry a bit that you're losing what razor-thin safety margin we have in a crash in these trucks by defeating the collapsing column. Might be better combined with three point belts!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#5 | |
Maybe someone who's done it can chime in as to how much travel would be left after this mod.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Anyone who thinks there is a safety issue with collapsing the lower shaft on the steering column should make sure their life insurance is paid up if they are in a head-on collision. Depending solely on the lower shaft to keep them out of the hospital or morgue you will quickly find out what a marvel of engineering it was.
Thanks Ben, I did collapse the column today, a little over (2) inches, and it's exactly what I was looking for. A relatively easy fix, I did use a lot of heat just like the link said - till the plastic oozed out. If you did go much lower, you might want to think about a tilt wheel because she does start getting pretty low. But then again, the seats I'm installing set a little high. Thanks again guys, I would have never thought of this.
Moderator
![]() Join Date: May 2007
It's done when installing a van tilt column as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Custom Sport W/T
Now that you have collapsed your column can you imagine doing that with your chest in a head on collision and being able to walk away?
