Old 03-13-2017, 03:18 PM   #1
jabos
What engine is this?
On the side of the engine by the distributor D 15 0
On the other side it says 3836848 GM 19
Thanks for the help I just got the truck and need to get some parts for it to get it running.
jabos is offline   Reply With Quote
Old 03-13-2017, 03:23 PM   #2
AtomicYJ
AtomicYJ's Avatar
Re: What engine is this?
That casting number comes up as '56-'62 head for a 235 ci I6
1957 Chevy 3200
1971 Jeep CJ-5 Renegade II
1983 Chevy K/10 Silverado
1985 Jeep CJ-8 Scrambler
AtomicYJ is offline   Reply With Quote
Old 03-13-2017, 03:26 PM   #3
jabos
Is the casting number 3836848?
Old 03-13-2017, 09:52 PM   #4
jabos
Well so does that mean the block is in that time frame also? Is there numbers for the block somewhere? The truck is a 51
Old 03-13-2017, 10:08 PM   #5
Mac the Yankee
The code you gave is for the head (good head by the way- high compression)
The engine code will be to the right of the distributor, and the date code will be to the left. The date code will look something like this:
C103
C= March (third month), the 10= day, and the 3= 1953
Mac the Yankee is offline   Reply With Quote
Old 03-14-2017, 07:13 AM   #6
jabos
So does the D 15 0 mean the engine would be April 15 1960 since the head is from that time frame?
Old 03-14-2017, 03:02 PM   #7
AtomicYJ
AtomicYJ's Avatar
I think that would be a good guess on the date. I bet someone swapped in a later 235 to replace a worn out 216.
1957 Chevy 3200
Old 03-14-2017, 03:11 PM   #8
jabos
Well I guess that is good it is a 51 3600. Did they put the 216 in those trucks?
Old 03-15-2017, 01:03 AM   #9
mr48chev
mr48chev's Avatar
Photos are worth a thousand words. Meaning that some of us can ID engines or other piece with photos reasonably easily.
Check this link, it has the head and block casting numbers for most all Chevy sixes.
http://1954advance-design.com/Stoveb...g-numbers.html
My ongoing truck projects:
Old 03-19-2017, 08:17 AM   #10
jabos
Old 03-19-2017, 02:40 PM   #11
AtomicYJ
AtomicYJ's Avatar
That's the stamp code they started using around '55-'56 I think. Made at Flint on April 16 of whatever year the motor is, and I believe A is a passenger car 235 application code.
1957 Chevy 3200
