Old 01-14-2017, 08:47 AM   #1
66clow
66clow's Avatar
Column shifter jumps upon acceleration
What might cause my column shifter to jump on initial acceleration in drive gear? It does not jump out of gear, the shifter column (handle and attached column) flops.
66clow is offline   Reply With Quote
Old 01-14-2017, 09:10 AM   #2
James the III
Re: Column shifter jumps upon acceleration
broken motor mount.
James the III is offline   Reply With Quote
Old 01-14-2017, 10:27 AM   #3
kaycee
kaycee's Avatar
Transmission or motor mount
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 01-14-2017, 11:54 AM   #4
hamjet
hamjet's Avatar
I don't know the shape of your truck, but worn , broken cab mounts will do it also..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 01-14-2017, 12:14 PM   #5
Boog
laying low
Boog's Avatar
Also incorrect auto shifter linkage will cause it to move. The correct linkage uses a bell crank from frame rail to trans. Short story is as the engine and trans torques over on acceleration it moves the linkage upward too thereby moving the shift lever. Over the years the original shift linkage may have been lost and a direct shift rod used instead. It works. Just not like original.
I don't have pics with me but you can search for auto shift linkage and see pics of what the right linkage looks like.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-14-2017, 12:19 PM   #6
66clow
66clow's Avatar
I'm starting to think it may be my linkage. Not too long ago I tried adjusting it so the indicator lined up. Later to realize the indicator I have is the wrong indicator for my trans. I'll start there, may be too tight. Thanks
Old 01-14-2017, 12:48 PM   #7
Boog
laying low
Boog's Avatar
I found this thread. There are many.
http://www.67-72chevytrucks.com/vboa...+shift+linkage
The pics are of the oe linkage. I think you can see how it works to control the torque movement vs the shifter. There are aftermarket linkages that are of the direct rod type and they do work but there is the lever movement issue upon acceleration.
Boog
primer is finer
Old 01-14-2017, 09:08 PM   #8
Shady Rascal
Shady Rascal's Avatar
Motor mount is my guess.
It's easy to check. Open hood. Start engine and hold your foot on the brake pedal. Then drop it in drive and goose the throttle whilst holding the brakes hard. Watch to see if the engine moves around when you go from park to drive.
Shady Rascal is offline   Reply With Quote
Old 03-19-2017, 06:33 PM   #9
66clow
66clow's Avatar
Found my problem. PO left bolt out or didn't install. Does it use just a bolt or a Bolt & Nut? 350 and I know about the power steering crazy bolt set up
Old 03-20-2017, 09:23 AM   #10
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
The bolt is a 7/16" std. thread about 1" long with a thick flat washer or just use 2 regular flat washers and a lock washer. These bolts are often a pain in the shorts to get in if the holes were not enlarged to at least 9/16". Good luck, Capt.
CaptRMW is offline   Reply With Quote
Old 03-20-2017, 09:25 AM   #11
66clow
66clow's Avatar
Thank you fellow floridian!
