Old 12-28-2016, 01:57 PM   #1026
Re: Project two tone.
Nice going TJ. Slowly going back to being a truck again!
Old 12-29-2016, 11:52 AM   #1027
TJ's Chevy
TJ's Chevy's Avatar
Thanks Palf!
Old 12-29-2016, 12:55 PM   #1028
Ta2Don
Ta2Don's Avatar
Looks great Brotha!!! Enjoy the coming year!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 12-30-2016, 12:22 AM   #1029
TJ's Chevy
TJ's Chevy's Avatar
Thanks Brotha!
Little early, but Happy New Year folks!
Tiny update to end the evening. Had a few minutes so I got my fuel pump mounted up and the rest of the line routed. She's set permanent folks! One more thing off the list.
Later guyz.
Old 02-17-2017, 08:06 PM   #1030
GMDad
GMDad's Avatar
Do you have a build up on your motor or did I miss it. I am redoing my 65 ickup. It has had a stock 292 and 5 speed in it for about 20 years and want to update the motor. What did you use for pistons and a cam?
GMDad is offline   Reply With Quote
Old 02-17-2017, 09:28 PM   #1031
TJ's Chevy
TJ's Chevy's Avatar
I don't, but here's what has been done:
Head work:
1.94 intake and 1.60 exhaust valves.
Lump ports
.030 shaved off the bottom
BBC screw in studs
Comp cams 1.75 ratio bbc roller rockers
Z/28 valve springs
Block work:
zero decked
.040 over ross forged aluminum pistons. .170 dish and 100+ grams lighter than stock
Stock rods balanced and refitted with arp studs and bolts.
Crank ground and balanced.
Comp cams 268H 219@.050 .499 lift 110 lobe center
Comp cams lifters
Smith brothers pushrods.
Aluminum timing gears
Clevite rod, main, and cam bearings.
Melling stock type oil pump.
Misc:
Clifford Intake and short tube headers
625 CFM demon carb
DUI 50K HEI
12bolt.com finned aluminum valve cover.
Old 02-18-2017, 01:17 AM   #1032
GMDad
GMDad's Avatar
Thanks. My head is the same as yours but didnt shave anything off it. What compression were the pistons? Do you know what final compression ratio is? Have you put any miles on the motor yet? Happy with it?
Old 02-18-2017, 01:24 AM   #1033
TJ's Chevy
TJ's Chevy's Avatar
Well the total compression should be around 9:4:1 - 10:0:1. Not entirely sure. Pistons themselves would have been good for around 9:0:1. No miles on the motor.....truck ain't close enough to being back together for that. haha Very happy with it thus far. I know of many that have done similar builds to this and have had great success so I am fully confident.
Old 03-03-2017, 05:35 PM   #1034
TJ's Chevy
TJ's Chevy's Avatar
Hi guys! Well it has been awhile since the truck has been touched. Weather took a turn for the worst and work was super slow.
Spring is around the corner and the weather should be getting better soon which means....Painting time!
So plans are to fire up and break in the 292 sometime within the next two months. Shooting for May. Already getting the ball rolling. Got a list of the last needed parts to get her running and it's already getting smaller. Super excited about getting that motor running.
This weekend I will be doing some small work on the truck. Today I picked up a new starter, hose fittings, fan belt, thermostat, and some other misc stuff. Parts are on the way from Classic Parts and should be here sometime this coming week. Also with the help of my dad I'll be setting the cab right side up on the stand to start working on the floor this weekend so I am excited about that! Hope to have the entire cab in primer late spring early summer and then onto painting.
Lot's to do folks! Until next time!
Old 03-03-2017, 05:42 PM   #1035
Looking forward to the vroooooooooom
Old 03-03-2017, 10:45 PM   #1036
TJ's Chevy
TJ's Chevy's Avatar
Me too! Thanks man!
Old 03-04-2017, 09:51 AM   #1037
Ta2Don
Ta2Don's Avatar
Get after it Brotha!!!
DON
Proverbs 27:17
Old 03-04-2017, 11:50 AM   #1038
TJ's Chevy
TJ's Chevy's Avatar
Thanks brotha! Good to hear from ya!
Hope you are doing well and they aren't working you to hard over there.
Old 03-06-2017, 10:40 PM   #1039
TJ's Chevy
TJ's Chevy's Avatar
Hey guys! Few small updates to get the week started.
Since I am planning on getting this engine going soon I've been working on getting it finished so it can be ran. Lotta small stuff still needed to be done.
Fan belt I had was too long so I got a shorter one and that takes care of That. lol See pic.
Also got my new starter mounted up. Still debating on painting it black.....Thoughts?????
Got some gasket maker and made some gaskets for the adapter plate and then purchased a 1/2 inch thick gasket for the carb mount. I'll show the reason for all that later this week. Had to raise the carb up a little.
Anyhow....also got some brass 90's for the water heating jacket on the intake manifold so I can rout the water hoses better.
Oh yeah, siliconed the thermo stat housing in place so that is on permanent.
Well all this and not much was done, but it beats nothing at all. lol Should have some better updates this weekend as parts will be coming in and I'll be trying to spend most of the day working on the truck. Weather has been cold and nasty as well so time to get the wood stove fired up!
Later guys!
Old 03-06-2017, 11:48 PM   #1040
Classic v6 GMC's
Classic v6 GMC's's Avatar
Making progress!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 03-07-2017, 03:14 PM   #1041
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by Classic v6 GMC's View Post
Making progress!
Thanks Jake! Slowly but surely!
Old 03-21-2017, 04:28 PM   #1042
TJ's Chevy
TJ's Chevy's Avatar
Afternoon Gents!
Through out the past week I have been tinkering with the 66. Weather has been bad so cab work has not happened, but parts have been coming in for the 66.
Got my hei dizzy in and plug wires cut to size.
Found this braided hose sleeving that I could not pass up so I have been braiding all the hoses. Not quite as good as the real thing.....but looks good none the less.
Also got my lokar throttle cable mount installed.
Old 03-21-2017, 04:31 PM   #1043
TJ's Chevy
TJ's Chevy's Avatar
Waiting on the lower rad hose which should be in tomorrow. Then I'll sleeve it up and install it.
Not much left to do to get this motor running.
Also got the cab set upright again to start working on the floors. Waiting on decent weather now.
All for now gents!
Old 03-21-2017, 06:49 PM   #1044
Ta2Don
Ta2Don's Avatar
Awesome looking Brotha!!! Waiting on a running engine video... Diggin' those headers...
DON
Proverbs 27:17
Old 03-21-2017, 09:34 PM   #1045
RANDY COX
RANDY COX's Avatar
T.J. I can't wait to hear that monster, I'm sure you can't wait either...Just takes time...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 03-21-2017, 10:42 PM   #1046
62stepside longbox
62stepside longbox's Avatar
Can't wait to hear it fire up!!
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 03-22-2017, 10:36 AM   #1047
TJ's Chevy
TJ's Chevy's Avatar
Thanks brotha! Super excited here!
Thanks for checkin in Randy! Yep, can't wait either! lol
Thanks man!
Old 03-23-2017, 08:44 AM   #1048
bj383ss
bj383ss's Avatar
Your rolling stock looks really good TJ. I remember when I was working on my cab and you kept saying someday. Know you are there.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 03-23-2017, 10:56 AM   #1049
TJ's Chevy
TJ's Chevy's Avatar
Bret
Thanks Bret! Yeah, goes slow....but goes fast at the same time. haha
Old 03-23-2017, 01:38 PM   #1050
66Z71
66Z71's Avatar
It will almost be a shame to cover that up with a body. Lookin good.
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera
66Z71 is offline   Reply With Quote
