Old 03-24-2017, 06:58 PM   #1226
62stepside longbox
62stepside longbox's Avatar
Re: Nik's 62 build
Spent a couple hours beating away at the passengers side and finally got them out, I then wire brushed the trailing arms and inside the holes and put on a little rust paint where the axle mounting pads sit. Before I install the rear end I will apply some anti seize to the ubolts. While I was under the truck I made a little discovery. I found that one of my coil springs is cracked right at the base. So it looks like I'll be in the market for new springs.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 03-24-2017, 08:55 PM   #1227
RANDY COX
RANDY COX's Avatar
Re: Nik's 62 build
Hey, you done a good job on that radiator support patch, let me guess it was the passenger side that was rotted.. from the battery acid...that's the same place where mine was and I just patched it like you did couldn't see getting a new one since that was the only place...keep up the good work...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 03-25-2017, 12:03 AM   #1228
62stepside longbox
Re: Nik's 62 build
Thanks randy, and yes the drivers side had no rust at all which had me scratching my head for a bit. But that makes complete sense about the battery acid leaking down, on vehicles of this age most of them seem to have rusted out battery trays for that exact reason.
Old 03-25-2017, 12:35 AM   #1229
AJCK87
Re: Nik's 62 build
Right on Nik! Looking forward to seeing you rig on the road. Hopefully I can get out to the Okanagan this summer, I will definetly drop you a line. Keep it up, in the home stretch now
AJCK87 is offline   Reply With Quote
Old 03-25-2017, 09:06 AM   #1230
62 Barnfind
62 Barnfind's Avatar
Re: Nik's 62 build
Make sure you get the new mounting plates and bolts. i had to cut one of my springs out and pound out the long bolt. Now you can order the the drop size you want and lower the front to match.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 03-25-2017, 10:52 PM   #1231
62stepside longbox
Re: Nik's 62 build
Thanks Anthony! I'm really wanting to see it on the road as well, shouldn't be long... Looking forward to hopefully seeing you this summer!
I was actually wanting to keep it stock height as I do a lot of fishing and dirtbiking in remote areas that require some ground clearance and beefier tires (the reason I got the Dunlop rover m/t's).
Today I got my new ubolts and bolted in the rear end, it's a great relief to see that all my measuring and welding was done properly and it all went together super smoothy. I then put the wheels on and put the truck back on the ground.
Old 03-26-2017, 09:16 PM   #1232
62stepside longbox
Re: Nik's 62 build
Worked on getting some small odds and ends ready on the engine, installed a few small parts. Put in the distributor and picked up some new plug wires, I had to trim a couple of them but other than that they worked perfectly. All I need to do is clean, paint and install the oil filter system and lines and it'll be ready to fire up!
Old 03-28-2017, 07:16 PM   #1233
62stepside longbox
Re: Nik's 62 build
Yesterday was a sanding day, lots of sanding. And today was a painting day. I stripped the radiatior, and sanded the hood latch piece, the front filler panels and the old 6 lug wheels. Obviously now that my truck is 5 lug I have no need for these 6 lug wheels, but I didn't pay anything for them as they came on the truck and I only paid $100 for the pretty much new whitewalls. So the plan was to sand and clean them completely, mask off the tires and paint them gloss black and then clean up the tires really well and put them for sale. I'm thinking I should be able to get about $500 for them which will free up some cash for other truck parts. So here are the wheels painted up, I just need to give the tires a good clean and post them for sale.
Old 03-28-2017, 07:20 PM   #1234
62stepside longbox
Re: Nik's 62 build
Here is the hood latch and filler panels all painted up.
Old 03-28-2017, 07:22 PM   #1235
62stepside longbox
Re: Nik's 62 build
And here is the radiatior all painted up
Old 03-28-2017, 07:28 PM   #1236
62stepside longbox
Re: Nik's 62 build
One of my buddies that was building a truck for someone ordered a few parts for a 250 six cylinder, but the customer changed his mind and wanted a v8. So he had no need for this part and have it to me. It's a upper rad hose for a 63-66 which is clearly too long but part of it has the same curve as the original 62 hose.
Old 03-28-2017, 07:29 PM   #1237
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: Nik's 62 build
Parts look nice!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 03-28-2017, 07:30 PM   #1238
62stepside longbox
Re: Nik's 62 build
And here is the hose cut to fit. This will be the last update for the next few days as tomorrow I'm driving a few hours to the coast to do some fishing, but I'll be sure to make some progress before school starts back up.
Old 03-29-2017, 01:10 PM   #1239
SSpeed66
SSpeed66's Avatar
Re: Nik's 62 build
I bought those WW's you linked to me a while back for $200, they are on older 6 lug rims with the clips for the caps. I got a good score there !
Living The Canadian Dream in British Columbia
SSpeed66 is offline   Reply With Quote
Old 03-30-2017, 12:35 PM   #1240
62stepside longbox
Re: Nik's 62 build
Originally Posted by Classic v6 GMC's View Post
Parts look nice!!
Thanks!
Yes that was a great deal! I'll be posting these for sale soon and I'll see what I can get for them.
Old 03-31-2017, 10:21 PM   #1241
62stepside longbox
Re: Nik's 62 build
Got back from my trip this evening and had time to bolt in the radiatior, front filler panels and hood latch. All is looking good. As you can see I haven't bothered to get rid of the lightbulb mounted on the hood. I've actually been using it to work at night
Old 04-01-2017, 01:06 AM   #1242
TJ's Chevy
TJ's Chevy's Avatar
Re: Nik's 62 build
Nice job man! I had the day off school for spring break and spent a good portion of the day working sanding the interior firewall and floor of the 66's cab. Tomorrow(saturday) morning I should be priming and painting. Have to be somewhere around noon so not sure on the paint....but primer none the less!
Old 04-01-2017, 06:20 PM   #1243
Re: Nik's 62 build
Looks good !!
The light-bulb is CHARACTER!
Old 04-01-2017, 10:47 PM   #1244
62stepside longbox
Re: Nik's 62 build
Thanks Tj, good to hear you're making progress as well!
Looks good !!
Thanks Bill, the lightbulb is one of those things that puts a smile on everyone's face, so it will likely be staying.
I decided to try to make the power steering high pressure hose instead of trying to find one with the correct fittings. The metal part of the line had a 90 degree bend in it and was far too long, so I straightened it out and cut it to the correct length.
Old 04-01-2017, 10:49 PM   #1245
62stepside longbox
Re: Nik's 62 build
I then made a nice Double inverted flare on the end and put the correct bend in the line. Here it is installed.
Old 04-02-2017, 08:02 PM   #1246
62stepside longbox
Re: Nik's 62 build
Today was the last day of my springs break, so I decided to get a few things done. First I cleaned all the grease and crap off of the oil filter canister and metal lines and painted them black. I wanted to leave the original sticker so I taped it off to preserve it while painting. Here is the finished product.
Old 04-02-2017, 08:03 PM   #1247
62stepside longbox
Re: Nik's 62 build
The top was aluminum so I just left it raw and polished it.
Old 04-02-2017, 08:06 PM   #1248
62stepside longbox
Re: Nik's 62 build
I wanted to do something a little more fun so I decided to install the gun rack I picked up a while back. Here is my 1970 slavia 620 testing it out.
Old 04-02-2017, 11:03 PM   #1249
TJ's Chevy
TJ's Chevy's Avatar
Re: Nik's 62 build
Nice!! Yeah, today is my last day of Spring break to.
Old 04-03-2017, 11:01 PM   #1250
62stepside longbox
Re: Nik's 62 build
Thanks buddy, going back to school today was a bit of a drag, but I guess I'll live through it
Today's project was to get the proportioning block mounted. I chose to mount it to the frame rail area below the brake booster. I welded two bolts on to the frame.
