Old 03-21-2017, 10:51 AM   #1
1tuff71
1tuff71's Avatar
kick panels
Not sure if this is the right place to start this thread but here we go. Has anyone here used the kick panels with speakers in them and will they clear the e-brake pedal ?? Is there a better solution to these? Don't want to cut the doors. Ideas with pic's ??
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
1tuff71 is offline   Reply With Quote
Old 03-21-2017, 11:05 AM   #2
buckkoo
buckkoo's Avatar
Re: kick panels
I have them in my 72 K5 with infinity 6.5" 2 way speakers, I have the ACC carpet with the heavy backing over dynamat, which I recommend.
I had to slit the side panel carpet from ACC to fit the side panel speaker enclosures, which turned our fine, using 3M spray adhesive.
As far as E brake, I drilled holes in bottom of dash and moved e brake bracket over an inch to accommodate added width of side panels, looks great, no issues.
Also built my on side panels, covering in 1/4 foam then factory vinyl, from a company out of Michigan. You can find the schematics on this site, which are perfect. I added 6x9 Infinitys in these panels and added back seat and rear cargo LED courtesy lights, which come on when the doors are opened.
Finally I built a sub woofer box out of Melamine and covered in extra carpet, that I bought from ACC. The sub sits in the back cargo area.
Receiver is by USA and works OK, amp is 5 way Infinity, placed under rear seat.
buckkoo is offline   Reply With Quote
Old 03-21-2017, 03:53 PM   #3
JJH Jimmy
JJH Jimmy's Avatar
Re: kick panels
I built mine using an old t shirt and fiber glass resin. I sprayed them with Raptor liner when done and turned out great.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 03-21-2017, 04:02 PM   #4
JJH Jimmy
JJH Jimmy's Avatar
Re: kick panels
Installed
1985 Chevy K20
1994 GMC Yukon
Old 03-22-2017, 04:21 PM   #5
1tuff71
1tuff71's Avatar
Re: kick panels
Thanks guys.
Old 03-22-2017, 06:45 PM   #6
cleszkie
cleszkie's Avatar
Re: kick panels
I moved the parking brake pedal pad over about an inch towards the passenger side on the arm and it now clears my kick panel speakers. Cut it off with angle grinder, welded it back on with a gusset to support the offset. Works perfectly.
cleszkie is offline   Reply With Quote
Old 03-25-2017, 09:14 AM   #7
1tuff71
1tuff71's Avatar
Re: kick panels
whats the $$$ investment. is it cheaper than the panels ?? I realize theres a certain amount of gratification in making your own but not sure its worth that but I'll try any thing once. Thanks for your help guys. I'm off to the parts store
Old 03-25-2017, 01:20 PM   #8
LuckyScott
LuckyScott's Avatar
Re: kick panels
I have the ones that you buy, not ones I made, and they work just fine. Clear the e brake just fine.
LuckyScott is offline   Reply With Quote
Old 03-27-2017, 01:56 PM   #9
cleszkie
cleszkie's Avatar
Re: kick panels
Mine were bought out of a catalogue too. But my pedal did not clear the speaker grille. Hence the relocated pedal.
Old 03-27-2017, 03:25 PM   #10
1tuff71
1tuff71's Avatar
Re: kick panels
So the "flusher" the speaker grill is the less chance of a clearance problem using the prefab panels. Correct ?
Old 03-28-2017, 07:53 AM   #11
buckkoo
buckkoo's Avatar
Re: kick panels
Thinner speaker = sound compromise, get the speaker you want, then move e-brake handle as needed. Not a big deal.
Old 03-28-2017, 01:47 PM   #12
cleszkie
cleszkie's Avatar
Re: kick panels
I believe my pedal pad made contact with the kick panel itself (pedal pad hit kick panel even without speaker installed).
Old 04-01-2017, 10:42 AM   #13
1tuff71
1tuff71's Avatar
Re: kick panels
I'll try and make my own just because I feel like having a " one of a kind ". it's whats cool about our trucks and why we build them. This has to be the best sight for chevy trucks. Thanks to all with your help. Now if I could just find a set of those front shock hoops. I know someone has a set sitting in a corner of their shop.
