Old 03-26-2017, 01:47 PM   #1
randy.powell
Stock A/C Clutch Pulley Diameter5" or 6"?
Going to order a new compressor for my 71 C10 w/factory A/C and one of the questions I can't answer is the diameter of the clutch pulley. Options are one with a 5" or 6". If my truck wasn't 100 miles away I could just go out and measure it.... Searched the forums extensively but can't find that tidbit.
TIA,
Randy
randy.powell is offline   Reply With Quote
Old 03-26-2017, 02:22 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Stock A/C Clutch Pulley Diameter5" or 6"?
I can't measure mine since I'm farther from my '69 than you are from your truck. But this may help. I found a new compressor (R12) on Craigslist for $50. However, it has a smaller pulley than my original. So, my guess is you want the 6" pulley. Here are pictures of my original and the new one for reference.
FirstOwner69 is offline   Reply With Quote
Old 03-26-2017, 02:27 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If it helps, the OEM pulley on my '72 K20 is 5".
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-26-2017, 07:22 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Mine ('70 C20/402) is 6". Maybe the difference is BBC Vs SBC?
~Steven
Simi Valley, CA
Last edited by Steeveedee; 03-28-2017 at 04:32 PM. Reason: deleted unnecessary info
Old 03-28-2017, 12:52 AM   #5
tdangle
tdangle's Avatar
I would think if you had low gears then the 6" would be better as it would turn the compressor a little slower. If you have high gear ratio a 5" would be better.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
