03-03-2017, 07:50 AM | #1 |
wifey not happy
weird problem hopefully someone can help with advice
door handles and locks were working fine manually with the button that sticks up through the door panel and also would lock and unlock with the keys. problem came when i tried to use the power locks the button worked to lock both doors but the passenger door won't unlock now the power button won't unlock it or the button on top or the key the driver door is ok but wife can't get in on her side lol I asked her to climb through the window since i noticed she was wearing a skirt but she didn't see the humor in it. 91 blazer
1991 K5 Blazer 4x4 "9 ball" 2019 Chevy Silverado Trail Boss 4x4 2018 Chevy Colorado 2 door ZR2 4x4 1988 23' Mako Marine 2005 Harley Davidson Road King |
03-03-2017, 09:19 AM | #2 |
Re: wifey not happy
My passenger side just broke a few weeks ago and I fixed it yesterday. The lock rod that sticks out of the top of the door inside (your interior lock), connects to lock mechanism AND the electric actuator.
In other words, at the 90 degree elbow that has a plastic securing clip, it goes into lock hole and then into the actuator hole. Basically, 2 in 1 job. Before I could get into the truck so it stayed in the garage until I could get it fixed..
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
03-28-2017, 06:51 PM | #3 |
Re: wifey not happy
My passenger side door does the same thing from time to time. What I found is that the exterior door button partially sticks in the "in" position, so I have to push and release the outside button as fast as I can to make it pop out. It probably needs some lubrication or a new outside door handle but I haven't had the time to work on it. Hope this helps.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
