#76 |
![]() Join Date: Feb 2014
Re: A quick look at the Hickey worm gear winch
Jeff, this looks great. I'm very impressed. Bruce
Posted via Mobile Device |
#77 | |
It's been a fun project. Now I just need a lever extension and skid plate and it will be a wrap! I will post pics of the lever extension that came with the winch. Now that the winch is actually installed you can see how the last owner had it setup! I plan to make one that comes out in front of the grill.
White K20 |
#78 |
nice job! a jigsaw? really? I had visions of a torch. Good to know.
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
#79 |
Original winch owner used this piping with a small offset and a set screw. It was accessed by popping the hood and reaching between the grill and radiator. He my not have had air because it comes pretty close to my condenser. But I would rather not pop the hood to operate the winch anyhow.
This morning I did a mock up of a flat bar extension to come up through the bumper right in front of the grill. It has a lot of holes for mock up. It bolts to the clutch handle and snakes through the bumper in front of the grill. I had to jockey it around a bit to get it were I wanted, so I bolted the joint at first to get the angle correct and height on mounting on clutch handle, then I welded the joint. Guess I never took pics of it coming through the bumper in front of the grill. Now that I have it mocked up I can cut, bend and weld a clean one. Then I'll post some installed pics. Original owners clutch handle extension Clutch handle extension coming between grill and condenser. My flat bar extension side view. More offset to come out through bumper. Front view of flat bar extension.
White K20 |
#80 |
Finished making a hasp plate for the extended handle a few days ago, finally installed it today.
About the extended handle and hasp plate. I decided that I did not like the idea of someone being able to walk by and maybe slap the clutch lever and set the spool into free. Although I keep a bit of tension on my cable, and it is hard to move the handle, I am a bit cautious. With a short 6" handle you probably need to pull pretty hard to get it into free with out letting up tension on the line. But now my handle is probably close to a foot or maybe 10 inches longer, much more leverage. So I drilled a hole in the handle where it protrudes from the bumper; and made a hasp plate with a corresponding hole. Put on a 5/6" hitch pin to keep it locked down. The extended handle works great! Here's the results.Hasp plate masked for lettering and final black coat. Hitch Pin Installed with hitch pin. There is 1/4" between the handle and the hasp, they never touch. The handle does not rattle around at all. The setup works great.
White K20 |
#81 |
Nice one, you think maybe a lock would be better so nobody will play with it?
From free to lock, approx. how many degrees? 12 or so?
#82 | |
Thought about a small lock, but if someone really wants to take the time to remove the hitch pin and mess with it.... then I probably got bigger problems. Plus I lose keys; and I like the convenience of everything accessible up front and ready for service, kind of a no frills deal.... just business.
White K20 |
#83 |
Calling this project done for now. It'll be awhile before I get around to making a skid plate or custom bumper. Though I have decided on an aux battery setup in the near future. I didn't mind cutting my bumper, taking a serious look at it I decided I need an new one.
Before and after pics.
White K20 |
#84 |
Nicely done, really looks great. How do you post pics here? I use your thread as inspiration to start my worm drive rebuild. Bruce
#85 |
Thanks Bruce, I really love the winch!
Posting pics is a two part deal. 1) Go to manage attachments below your post, before you submit the post,and browse for the image and click upload. 2) After the image is uploaded go to the paper clip in the tool bar and select the image to get the tag of the image to show in the text you are typing. This way you can write something above or below the image, by typing above or below the image tag. If you only do step 1 your pics will be lumped together.
White K20 |
#86 |
nice write up. i have a worm drive winch. the clutch handle is stuck and i can't move it to free. what do you think is wrong?
#87 |
Either the handle shaft or dog are rusted. But everything on the handle side of the case gets rusted. You just need to pull that end of the case off, wire brush it and grease it up. That is most likely the problem. When I first ran mine to test the motor, before disassembly, it kept popping out of gear. And that's because it never fully engaged due to rust. The iron is so heavy that the rust should just wire brush off!
White K20 |
#88 | |
Why do you not like the mounts?
#89 |
I was critical of the mounts on my first visual inspection because of the notch. That was just my first thoughts really. But the mount iron is 5/16(darn thick!). So I'm guessing they accounted for the notching with the thicker iron. I'm guessing some other things will bend before the mounts. No longer an issue for me. I will be leaving the winch mounted as is.
White K20 Last edited by jeffahart; 03-28-2017 at 08:47 PM. |
#90 |
Got rid of the roller fairlead and replaced with a steel hawse. Painted everything black and did some painting on the grill. Working on second battery now.
j
White K20 |
#91 |
![]() Join Date: Feb 2007
that's a nice option that keeps the stock pumper. grats!
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#92 | |
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#93 |
jeffahart and dazza,
Thanks for the great pictures and install/rebuild info. I might be the proud owner of one of these by the end of the week. I paid by Paypal and have tracking numbers but sometimes you just never know about interweb purchases.....If I need to go through it when it arrives I'll be using your guidance here for sure so thanks again. jeffahart, I like the clean look of the hawse fairlead, I'll be using the same set up on my bumper that just got delivered last week. Here is what it is going on. I have tow hooks so I'll be skipping the shackles.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch! |
#94 |
One of the things you can do with a steel hawse is stick your finger around a ball or u-joint and finger scrape a bit of excess grease; and then swab the hawse hole before you run line. Helps a bit, especially if you have a used hawse with a bit of rust.
White K20 |
#95 | |
White K20 |
#96 | |
#97 | |
![]() Anyhow, if you have access to a machine shop, and if you have to replace the motor, I would get the large collar gear and seal kit and give it a good look over. I didn't want to pay to have my motor fixed, and the only new one I found was north of $300 (a kings ransom for a simple motor like this). So I went with the cheap maintainable route. I'm not calling my decision good or bad, just my decision when I was at the motor/gear crossroad! In the end I got the 10 spline motor working, go figure! I gave it to Bruce. You can have my old gear if you want it, pretty sure I still have it. Might be in a bit better shape than yours, not sure. I can dig it up an photo if your interested. ![]() j
White K20 |
#98 | |
. I do have access to a very decent machine shop and will be going the same route that you took. It will be easier to get parts and maintain after converting to the newer gear and seal. I don't know anyone who would say "I won't need to maintain that" although most winches probably don't see much action. The winch I have was covered in silicone sealant and that seal in particular was covered in it, so I know it was leaking and the previous owner obviously attempted to cure the issue but couldn't get that drive gear off. I just got back from my business trip so looking forward to some quality time with the winch and bead blaster. More pictures of the Hickey winch to follow...how kool is that going to be? Who doesn't want more pictures of Hickey winches...?
#99 | |
I figure if I have to swap my motor I will pull the winch and probably open the transfer case; but it will be nice to not have to pull the gear. I'm now looking forward to the hex nut stripping out after it freezes! But my main point I wanted to make besides being a smart A$$. Regarding leaking transfer seals, if they do leak and you went with the old setup... I think these transfers are a perfect candidate for corn head grease. If you've never herd of the John Deere Corn Head grease check it out. In a nutshell, it's grease until it get's warmed up by the gears, then it becomes an oil. Then thickens again when it cools. It won't leak. These things aren't like transmissions or rear ends, they run short bursts at low speed. So a maintenance free lubricant is tempting. I wouldn't hesitate to use it in the main housing with the worm and bronze gear either. I considered filling mine with corn head grease. When I put the oil in I wondered if I would ever change it, not likely. So, I considered a fire and forget lubricant like the corn head grease. But I put oil in for the bench test and it's stayed that way so far. I run the winch line out about five feet every time I wash the truck, just to keep oil spun up in the top. If I used the corn head grease, it would stick a bit better up high and I could probably go quite a while without running the winch. Just another two cents! ![]() Oh and yes... Pics Pics Pics... we love pictures of winches! j
White K20 |
#100 |
Hhmmm, corn head grease, that's a new one for me. Let everyone know how that turns out. I do have a question about how you mounted yours. I mocked mine up (no guts inside it just the end cases and mount bars). When I put the unit up to the frame the mount bars hit the leaf spring shackles. Specifically they hit the mounting rivets of shackle. I doesn't matter if I move the winch slightly back or more forward, it will hit either way. Also if I do move the whole unit more forward I run out of frame to drill any new holes (the holes would be too close to the frame edge). Do you have any close up pics of your mounts, maybe from the bottom? Did you have to use any shims to get it to work?
| Bookmarks |
