Old 03-30-2017, 09:39 AM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Re: This an original jack handle stow-away bag?
Originally Posted by 71CHEVYSHORTBED402 View Post
Well, one end or the other goes into the bottom pocket. Top pocket is pretty tight, especially where there's a vent assembly. Funny thing is, I was just talking to Wes today and ordered a fuel sender. He asked one or two lines, and I was "say what?". Well, the sender on the 72 has two. Learn new stuff every day.
Incidentally x2 Doc, you led me to the seat adjuster wire. Didn't know they existed. I figured the one on the 72 was monkey rigged, but turned out to be just broken. Not sure what was used factory for tension, but I made due with two small quick links.
There were a couple of different tensioners, one was an "S" hook that fastened to the back of the seat frame and the wire hooked into it and one was a small spring that hooked on the wire and back of the seat frame.
LockDoc
Leon
Old 03-30-2017, 02:37 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
LockDoc
I found the tiny S-hook for my 71 tension rod. I've seen at least two different rods, and I think you've mentioned that as well.
Good to know about the wire Doc.
On topic of adjusters, I found some variances in the height of the adjuster plates. Pretty sure it was height Vs thickness Couldn't tell you why, years or whatever. A grinder works.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
