![]() Join Date: Feb 2009
This an original jack handle stow-away bag?
Just installed a seat adjuster wire on my driver. Nice to have an operable seat, but discovering a jack handle behind the seat to make for a complete jack set-up was pretty cool too. This an original stow-away?
I'd describe the bag as heavy polyethylene foam. It's sewn shut less the strings stapled onto the bag to close it. ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-29-2017 at 09:30 PM. |
#2 | |
The Older Generation
Re: This an original jack handle stow-away bag?
http://67-72chevytrucks.com/vboard/s...d.php?t=411002 LockDoc
#3 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#4 | |
LockDoc
Well, one end or the other goes into the bottom pocket. Top pocket is pretty tight, especially where there's a vent assembly. Funny thing is, I was just talking to Wes today and ordered a fuel sender. He asked one or two lines, and I was "say what?". Well, the sender on the 72 has two. Learn new stuff every day.
Incidentally x2 Doc, you led me to the seat adjuster wire. Didn't know they existed. I figured the one on the 72 was monkey rigged, but turned out to be just broken. Not sure what was used factory for tension, but I made due with two small quick links.
#6 | |
There were a couple of different tensioners, one was an "S" hook that fastened to the back of the seat frame and the wire hooked into it and one was a small spring that hooked on the wire and back of the seat frame. LockDoc
#7 | |
Good to know about the wire Doc. On topic of adjusters, I found some variances in the height of the adjuster plates. Pretty sure it was height Vs thickness Couldn't tell you why, years or whatever. A grinder works.
