Old 03-30-2017, 03:32 PM   #1
81square
250 to 327 swap?
I have a 1968 327 block thats completely rebuilt but has none of the plumbing, distributor, fuel pump, etc. Just a rebuilt block. I want to put it in my 81 k10 that currently has a 250. Any estimates on how much it would cost just in parts to complete the swap? Labor doesn't matter because I'll be doing it with my grandpa. I was thinking probably somewhere around $1,000 to $1,500? Any input appreciated.
81square is offline   Reply With Quote
Old 03-30-2017, 06:16 PM   #2
Dead Parrot
Re: 250 to 327 swap?
How complete is the 327? Heads and full sheet metal or just a finished short block?
Transmission type?
Do you have the accessories brackets for the 327? Depending on year of 327 and if you kept the original heads, SBC brackets for your year of truck may not fit. My 68 Impala with a 327 had the Alt on the driver's side and AC compressor on the passenger side.
You will probably need:
V8 HEI distributor
Intake of choice
New carb or injection setup
starter
water pump
fuel pump
fuel pump to carb tubing/hoses
exhaust manifolds/headers/exhaust system
New water hoses
New belts
air cleaner housing and associated tubes and hoses
throttle & transmission linkages & brackets for them
starter
new senders for lights/gauges
maybe new fan, fan clutch, fan shroud(not sure if 6 vs 8 is different)
new AC compressor hoses if equipped and current hoses won't work on 327.
motor mounts
Sure I have missed a few things.
Dead Parrot is offline   Reply With Quote
Old 03-30-2017, 08:16 PM   #3
81square
Transmission type?
V8 HEI distributor
Intake of choice
starter
water pump
fuel pump
New water hoses
New belts
starter
motor mounts
It is a complete block with heads and intake manifold, and I have exhaust manifolds for it. I am planning on using the TH350 that's currently in my truck, but I also have a 400 I could use.
Old 03-30-2017, 10:17 PM   #4
andyh1956
Do the heads on your 327 have the assy mounting holes in them?
If you were closer I'd give you everything you'd need!
andyh1956 is offline   Reply With Quote
250 swap, 327, 327 swap, estimate
