Old 04-04-2004, 03:53 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
Hey pals:-) , I need help with Pioneer CD wiring I.D..
I have used Pioneer single CD player , Model DEH-43 to install in this 84 and I found that the manual that was in the glove box wasn't even for a pioneer, Gee !what a surprise. anyway A manufacturer tends to keep the same wiring throughout their line so anyone with a Pioneer player may be able to help me . I'll list the wire colors and Only a few still have ID one them and I'll list that. I need you to fill in the blanks for me . Thanx in advance , DAVE
red=ACC
orange=battery+
blue= remote control(not!)
solid black= prolly ground. but not marked =?
black w/green stripe=?
green w/red stripe=?
black w/gray stripe=?
gray w/red stripe=?
solid gray=?
gray w/black stripe=?
solid green=?
green w/black stripe=?
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 04-04-2004, 05:10 PM   #2
kevhill85
91 SWB 383
kevhill85's Avatar
i'll get it to night .
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040,
http://photobucket.com/albums/q169/k...ahoe prostreet
kevhill85 is offline   Reply With Quote
Old 04-04-2004, 05:22 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
http://73-87.com/mike/49734CRD3311A_...1332357300.pdf
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 04-04-2004, 07:01 PM   #4
shavedchevy
shavedchevy's Avatar
Hey thanks Mike that even cleared up some things that I have always wondered.
Dennis
shavedchevy is offline   Reply With Quote
Old 04-04-2004, 08:57 PM   #5
crossy
crossy's Avatar
guess it's my UNlucky day because the wiring there was not the same as mine ?? maybe just that one letter in the model made the difference. thanx , DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 04-04-2004, 09:16 PM   #6
swervin ervin
Well I tried.
Go over to Pioneer's site and see if you can find yours.
http://www.pioneerelectronics.com/pn...6_2128,00.html
Mike
1985 Chevy C-10
Old 04-04-2004, 10:33 PM   #7
crossy
crossy's Avatar
I did that before i posted and i couldn't find it , guess they only keep real current models listed. thanx , DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 04-04-2004, 11:35 PM   #8
Lynx
Lynx's Avatar
Most of those wires SHOULD be the same... the ones where you have: solid green and green w/black stripe... ect will be your speaker wires. Black Is always ground
But if you can get power, ground and switched power, you can pretty much safely figure out the rest of them by trial and error
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 04-04-2004, 11:51 PM   #9
crossy
crossy's Avatar
I think the green/blk, grn, gry, gry/blk are the FOUR speaker wires and the black is the common speaker ground to all and not the radio ground like i thought, what has me puzzled is the grn/red, gray/red, and the blk/gry. DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 04-05-2004, 12:23 AM   #10
Jonboy
Slots go on anything!
The blue wire is the remote wire (also used for power antenna or switched power to an amp.). I am pretty sure the rest are speaker wires.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-05-2004, 01:27 AM   #11
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
I doubt that any newer stereo uses the common speaker wire. Hooking it up like this is asking for disaster. The new amplification methods require each speaker have it own positive and negative wires. As said, the blue is a remote turn on wire used by an external amp. Most manufactures use a color scheme similar to the gray(+) & gray/black(-) for one speaker, green(+) & green/black(-) for another, green/red(+) & black/green(-) for a third, etc. Hope this works for you.
NeCrOmAnCeR is offline   Reply With Quote
Old 04-05-2004, 03:29 PM   #12
Ric83
Ric83's Avatar
By your listings, it appears that you will have a common ground for speaker, but it will be a common for the rear and a common for the front. i.e. - green/black one side, green/red other side with the solid green wire as the common ground. Same would be for the greys.
The solid black will be the ground for the radio as you first suspected. The blue your remote wire for power antena or an amp, and your red and orange are your constant and switched power.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 04-05-2004, 06:56 PM   #13
flip66
flip66's Avatar
Should be as follows. Font and rear may be wrong but I am sure about the left and right and pos and neg Pioneer has been that way for years.
red=ACC
orange=battery+
black w/green stripe= Rear left neg
green w/red stripe= rear left pos
black w/gray stripe= rear right neg
gray w/red stripe= rear right Pos
solid gray= front right pos
gray w/black stripe= front right neg
solid green= front left pos
green w/black stripe= front left neg.
flip66 is offline   Reply With Quote
