![]() Join Date: Feb 2009
Want to upgrade to a BBC 4 core radiator, what is needed?
Looking to upgrade a 76 C10 to a BBC four core radiator. The truck currently has the stock 350 engine and stock radiator.
Will I need anything else besides the following parts? Upper mount panel https://www.brotherstrucks.com/75-80...tinfo/RSC8003/ BBC Shroud https://www.brotherstrucks.com/73-87...tinfo/FS07387/ New rubber pads https://www.brotherstrucks.com/73-91...tinfo/RRP8704/ New radiator mounts https://www.brotherstrucks.com/73-80...tinfo/RSM8001/ Thanks in advance, Wes
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
Re: Want to upgrade to a BBC 4 core radiator, what is needed?
you wont need the core support mounts to install your new radiator.just the shroud, upper mount panel and the rubber pads...you got it covered,
At the body shop.
And possibly nut serts for the top of the core support.
My 77 wasn't threaded on the topposite of the core support.
" That didnt make it any newer " " Dont antique the equipment " |
#7 | |
At the body shop.
3/8 x 16 where a perfect fit.
![]() Join Date: Jun 2016
You will get better cooling with a modern 2-core aluminum replacement. Instead of 4 small rows, they have 2 big rows. Air flows through them better and they have a better BTU rating. Even the cheap alum/plastic replacements from your local chain auto parts will work. I have one in my dually cooling my 454 and I have no issues keeping things cool while towing with the A/C on in Phoenix in August.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
Spectra Cu730 radiator is a direct replacement for the 454. Works great
72 2wd k5 blazer 86 c10 "Red",76 2wdK5 "Bertha",77 2wdK5 "48",79 c10"Buster" GONE |
At the body shop.
I have one in my '73 it wasn't perfect, was just a shade to tall made the shroud all wonky.
