Old 04-05-2004, 08:40 AM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
auto-manual
Have a couple questions concerning electrical connections in the subject swap.
Background, I put a 1970 auto cab on a 1971 manual chassis. I swapped the auto steering column for a 1970 manual column. Of course i was unable to hook up the two connectors (neu. sfty and back-up) on the column.
What do I need to do with these two connectors? I already shorted the neu sfty connector. But what about the back-up connector? I'm also having problems with the function column items: Hazards work, turn signals do not. Horn does not work but have ground under button. Dash lights work, headlights, high beans work front side marker lights work. Parking lights not connected. rear wiring harness cut before rear cross member. Any insight?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-05-2004, 09:23 AM   #2
JimKshortstep4x4
Talking
Do you have the column shift transmission or the floor shift transmission?
Jim
Old 04-05-2004, 09:52 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Jim, it's a floor shift 4wd 3/4 ton.
Old 04-05-2004, 10:34 AM   #4
JimKshortstep4x4
Talking
You could connect the back up lights to the backup light switch on the transmission. Someone may have the necessary wires.
Jim
Old 04-05-2004, 11:24 AM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Your turn signals may not work because your rear harness is not connected to the tailights yet. It will not blink, even up front, but your signal indicator on the dash should light up solid green. This was GM's way of letting you know a bulb is burnt out. That's my recollection anyway.
As for the backup lights, Jim is correct. Do you have your old engine harness still? (the one the starter is wired up with). If so, this harness will have the proper pigtail for the backup switch on the tranny. f you splice this to your auto harnesse's backup wiring, it should work for ya. Yoy will have to get creative to route your wiring though.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-05-2004, 11:30 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Jeff, The bulbs do glow a faint green when I turn the turn signals on. The front parking lights are not there either. The harness from the firewall out is the one from the manual chassis, so I'll splice it in. Thanks!
Old 04-05-2004, 11:36 AM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
Then your turn signal issue should be resolved when you get the circuit completed and grounded. Good luck
Old 04-05-2004, 11:43 AM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Jeff, Did you order your Exhaust?
I never knew that about the turn signals! My day is complete, learned something new about my trucks!
Old 04-05-2004, 11:46 AM   #9
CPNE
Resident Curmudgeon
CPNE's Avatar
Not yet, still need to but the immediate need has been back-burnered since we just bought this
Old 04-05-2004, 12:10 PM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Jeff I saw that. Very nice. Why not make it 4wd? Which rear axle is that the H072 or the next one up, not sure about the RPO?
Old 04-05-2004, 12:15 PM   #11
CPNE
Resident Curmudgeon
CPNE's Avatar
Same axle housing as on the 3/4 tons I believe.
Old 04-05-2004, 12:22 PM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
So it's not an 11000lb axle? I thought they had a larger ring gear something like 12.5"
Old 04-05-2004, 12:29 PM   #13
CPNE
Resident Curmudgeon
CPNE's Avatar
Nope. The GVW on the vin tag reads 10,000. It's got a massive spring pack and overloads though.
Old 04-05-2004, 12:32 PM   #14
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Gotcha. Still 10000lbs is quite impressive. I was thinking of upgrading my rear brakes to the 13"x2" variety. I'm not sure if I have the 12x2 or 11.?x2.? ones yet. Will find out today when i pull the rear axles/drums off.
Old 04-05-2004, 01:37 PM   #15
Dean
Dean's Avatar
My turn signals did the same thing before I had everything hooked up and grounded. I wouldn't worry about the lights until you have everything hooked up.
I think you have the smaller of the two sized brakes on your 71. At least they looked smaller than the ones on both of my K20s when you were changing the wheels around. I'm sure they would be plenty of brake though. I have parts for the smaller ones if needed. You will have to change the backing plates and all if you go with the larger ones. I did this on my brothers truck..different backing plates, wheels cylinders, shoes, drums.... I don't think it was worth it. Some drums are finned and some aren't also.
Yeah those rearends are the same and I've even seen a few dumptrucks with 6 something gears in them. That would make a stump puller.
I got my stainless exhaust on saturday. I'll have to post pics soon.
Dean is offline   Reply With Quote
Old 04-05-2004, 02:03 PM   #16
Jeepster376
Jeepster376's Avatar
Where did you get stainless exhaust from?
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 04-05-2004, 03:06 PM   #17
Dean
Dean's Avatar
Stainless Mufflers came from Allen's Stainless in Indiana. I believe they were actually Chevelle mufflers. I custom bent all of the stainless pipe. Walker sells the stainless pipe in 10' sections. It was about $130.00 for three pieces. It sounds just right for me. I didn't want it loud and obnoxious like my other one with Borlas.
