Old 04-04-2017, 11:17 AM   #1
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Horn circuit ?
You should have continuity on the wire from the horn relay to the pin in the column.
disconnect the column plug and check the crimp on the wire from the horn relay to the column plug. You may have a break in the wire from the horn relay to the column plug if the crimp is good.
If either of these conditions exist then grounding the horn button won't blow the horn.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
