Closed Thread
Old 04-04-2017, 11:58 PM   #5176
custom10nut
custom10nut's Avatar
Re: What did you do to your truck today? Chapter II
I got my new Bullet Shaped Center Caps in the mail today.
Wow, it was 2 days from order to delivery!
Tomorrow I put them on. I'll post a pic then
custom10nut is offline
Old 04-05-2017, 04:41 AM   #5177
Metaldoc
Metaldoc's Avatar
New sway bar, springs, pulleys and a clutch fan. I had to make a .125" stainless shim plate for behind the crank pulley so I could align the belts. It was also a 20" fan trimmed down and balanced, to 18" to fit the stock shroud.
Metaldoc is offline
Old 04-05-2017, 06:21 PM   #5178
66clow
66clow's Avatar
Fix the hole in my firewall. A lot less heat!
66clow is offline
Old 04-05-2017, 07:20 PM   #5179
67ChevyRedneck
67ChevyRedneck's Avatar
You're gonna be in trouble! That looks like one of your wife's "good" wash cloths!!!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline
Old 04-05-2017, 08:16 PM   #5180
66clow
66clow's Avatar
She will never find out. She won't step foot in it until I get AC. Lol
66clow is offline
Old 04-05-2017, 09:09 PM   #5181
74baggedbug
Installed a new 160amp alternator only to find out it was bad right outta the box.. hope to be up and running tomorrow
74baggedbug is offline
Old 04-09-2017, 06:51 PM   #5182
flashed
Looks good .
flashed is offline
Old 04-09-2017, 07:35 PM   #5183
mud.man.rj
mud.man.rj's Avatar
Firedemon, is that an auto with 3 pedals still, looks like it used to be a std.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 04-09-2017, 07:39 PM   #5184
Metaldoc
Metaldoc's Avatar
Door art on one side done
Metaldoc is offline
Old 04-10-2017, 12:47 AM   #5185
suburban99
suburban99's Avatar
Got my 6.0 LS in place and bolted down. Dirty Dingo mounts and cross member..
Very tight fit with the TH350 in stock position...hooked up throttle cable and installed my home pinned harness.
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline
Old 04-10-2017, 12:51 AM   #5186
KQQL IT
At the body shop.
KQQL IT's Avatar
Changed door seals, hated the glue mess and crappy fit.
Ordered the push on style for GMCpauls.
KQQL IT is offline
Old 04-10-2017, 09:39 AM   #5187
VWNate1
VWNate1's Avatar
Thumbs up Door Seals
Based on a tip I read here I bought the ?Dodge Dakota? (correct me if that's wrong) door seals from Steele Rubber Co. and installed them, they're made in America and so have much better quality and won't rot away in two years like the Chinese crappo ones do .
That 6.0 Liter engine looks impressive, I can't imagine feeding it .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 04-10-2017, 06:25 PM   #5188
findog78
I got those. Easy to install but a biznatch to close the doors. I have to slam mine.
findog78 is offline
Old 04-10-2017, 09:20 PM   #5189
ElKotze
ElKotze's Avatar
Put new rear end in my Longhorn, a GM 9.5 14 bolt SF, replaced my HO72. Just couldn't find any gears anymore, just Brake pads and bearings. So now I went from 4.11 gears to 3.42, very relaxed Highway driving now-2500 rpm @ 65mph! Plus, it's a lot easier on gas now. Good thing about that axle is there are a ton of different gears out there from 3.20's all the way up to 5.11 or so. If you got all the parts you need, you can do it in one weekend pretty easy.
'64 C10 LWB, 283, 5speed
'68 C20 LWB, 327, 4speed
'69 C20 Custom Camper Longhorn, 350, 4speed
'72 C20 Cheyenne Super, 396, TH400
'66 C60, 292, 4speed
ElKotze is offline
Old 04-11-2017, 08:57 AM   #5190
midniteblues
midniteblues's Avatar
Originally Posted by firedemon View Post
yes it was standard I went auto last winter haven't got around to pulling the pedal yet I been torn on weather to cut it or pull it it looks like a pain to pull . I still step on it when I go to start it makes me feel stupid every time doh
The pedal is easy to come out.
Take the bolt out on the leaver/push rod side of the pedal use a chisel or screw driver too open up the leaver and pull the pedal out the left side of the assembly .... real easy and leaves lots room for the left foot with the small brake pedal pad.
Yesterday I got the dash and doors mostly back together.
Put a guage cluster in and a matching wiring harness in instead of the hacked mess idiot lite cluster harness that was in it.
Better door handles and door locks that match the ignition key.
New dash pad
A good heater control,
New heater tubes,
Cleaned up and lubed inner heater boxes.
I gotta find my stash of radio of oe radio knob bucket mounts to put the radio and glove box in yet.
And I have a perfect 67 camaro steering wheel to put in too see if i like it better than the oe wheel but the column is coming out today for lube and cleaning.
And I'm gonna cut and weld up the heater core mounts so they fit my aluminum heater core.....then the outer heater box can go back in.
Hook up the auto meters
And put the seat in.
I'm kind of digging the multi colored body for now.
One day I'll blow it all apart and it will all be black like it orginally was.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 04-13-2017, 09:21 PM   #5191
samkost
samkost's Avatar
Past 3 Days......
Lower Body Moldings.
Assembled the Doors, Vent Windows, Side Glass and window/door mechanisms.
Door Handles, Locks, Cab to Door Seals, Mirrors and Window Felts.
Getting there!
samkost is offline
Old 04-13-2017, 11:31 PM   #5192
allchevy58
allchevy58's Avatar
Nice work. Looks like you have added to the collection since you picked up the 68 in Reno.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline
Old 04-14-2017, 12:50 AM   #5193
OregonNed
OregonNed's Avatar
Haven't addressed it yet, but walked by the truck this morning and saw a nice little puddle of coolant under the lower radiator hose, which was wet.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 04-14-2017, 07:46 AM   #5194
matthamby
Well, driver's side mirror fell out, that's what I get for putting something that looked like it belongs on a Ford on my Chevy!
matthamby is offline
Old 04-14-2017, 07:46 PM   #5195
NoStopN
NoStopN's Avatar
That's just your truck telling you not to put ugly parts on it.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 04-14-2017, 07:57 PM   #5196
54belair
54belair's Avatar
Today, I finally paid attention to what my truck was telling me. For some time, while trying to finish up my build, I have been fighting with door alignment. I managed to get the drivers door (and accompanying spacing) very close to what I wanted but the pass. door has been another story. Ive had the door off and on a few times seeking the correct location before I said screw it and let it sit for a few months. Today I decided to tackle it again and for some reason I suspected the hinges (the new aftermarket hinges). I dug out one of the old hinges and low and behold--they are made differently---only slightly, but they ARE different. Luckily enough I had a spare door in the supply room and even better the "old" hinges were very tight. So, now I have two "new" yet "old" hinges painted and ready to mount tomorrow. God, I hope this solves my issues!!!!!
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline
Old 04-15-2017, 06:15 PM   #5197
ElKotze
ElKotze's Avatar
Oil change. Short trip to warm up the oil
ElKotze is offline
Old 04-15-2017, 06:47 PM   #5198
GR8-68
GR8-68's Avatar
Finshed rear brakes and brake lines.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline
Old 04-16-2017, 10:17 AM   #5199
SoCoC10
SoCoC10's Avatar
Installed new 20" US Mags Ramblers
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 04-16-2017, 05:28 PM   #5200
mud.man.rj
mud.man.rj's Avatar
Ramblers are a really nice looking rim.
Mudman.
5.0 4spd std.
7" lift w 35's.
Closed Thread
