01-02-2017, 07:49 AM | #1 |
58 Fleetside bed
While working on my 58 Fleetside,the fender wells had been flaired,(not a good job)I have one side back to original but the other side is in bad shape.Does anyone sell patch panels for the Fleetside?
01-02-2017, 10:53 AM | #2 | |
Posted via Mobile Device |
01-02-2017, 03:41 PM | #3 |
Re: 58 Fleetside bed
I did stumble across a post here about using 1960 wheel arch patch panels,are they the same or would I need to replace both sides
01-03-2017, 09:05 AM | #4 |
OK i'm getting a better understanding of the differance between a 60 and a 58,I think the 60 is the same arch as the 58
01-05-2017, 08:40 PM | #5 |
I have also been told by "professionals" that the bottom half of 60 up is same as 58-59 Fleetside.
I replaced right rear corner on my 59 Fleetside by just rolling flat piece of cold roll to shape and tacking in. I reverse rolled an inch or so into the spear section because I think the seam would be easier to hide in the roll as apposed to the flat surface below it. Truck painted and you can't tell a thing. |
01-06-2017, 08:02 AM | #6 |
nice job scuzz
I think I will have my body guy stop by tomorrow,I can cut wheel out and replace it with a 60 one ,but there is the curve just above the opening.It will take me a day or two to make the tooling for a 5min job. |
01-06-2017, 11:37 AM | #7 |
Proud Vet that loves the USA
While the 60-66 fleet side beds look the same from the "bullet" down, the major difference is the wheel well opening. The 58-59 beds have about a 3/4 inch flat lip, whereas the 60-66 beds come to a point.
What I have been doing is taking a patch panel from the front wheel well opening of 55-59 fenders to fix that area. Bubba |
01-06-2017, 02:35 PM | #8 |
Scuzz, the bed job looks great. I noticed that you are in Tunnel Hill. My nephew has a blasting business called Flintstone MediaBlasting near Lafayette and does a lot of car parts. His name is Mitchel Kingsley, Just wondering if you know him.
03-15-2017, 06:33 AM | #9 |
Did anyone figure out what I can do?
03-15-2017, 10:28 AM | #10 |
is the opening close to a front fender opening? maybe a wheel opening patch panel from a front fender could be used? got any donor front fenders?
my fleetside box went to a good home. sorry, can't compare, but it looks kinda close to a front fender opening, kinda sorta in a way. |
03-15-2017, 05:21 PM | #11 |
I gave away my old rusted front fenders,could use them now
04-05-2017, 07:22 PM | #12 | |
He blasted my hood and several small pieces. |
