10-31-2016, 11:45 AM | #351 |
Re: 20" Truck Rally Wheels
10-31-2016, 11:52 AM | #352 |
Detroitsteel: https://www.instagram.com/p/BMFmJsNjf7N/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-31-2016, 12:25 PM | #353 |
10-31-2016, 01:10 PM | #354 |
A guy with a truck
"Off the shelf" custom billet 20" truck rallies are now readily available from usmag. Called the Scottsdale--sorry if this is repeat info
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-01-2016, 02:54 PM | #355 |
Us mag is what I was asking about, are they still 900$ ea, and are there other options maybe where u can bolt on the same oem stock center cap?
12-11-2016, 10:58 AM | #356 |
bad azz !!!
94 EXTENDED CAB 64 CHEVELLE |
04-06-2017, 12:49 AM | #357 |
Has anyone considered buying a cheap set of solid 20 wheels and taking them down to a cnc water jet cutter and having the holes cut. It's likely possible and likely way cheaper than the end result of buying a set of 900$ a piece wheels.
instagram - @custom.chevy |
