1962 4x4 Suburban
I just bought a sweet 62 4x4 Burb. And was wondering who makes new leaf springs? I would like to raise it a few inchs. I would also like it to have a reasonable amount of travel. Thanks Doug
Re: 1962 4x4 Suburban
Welcome.
Whats your idea of reasonable travel? If your Burb is a 1/2 ton and running 52s in the rear, the travel and ride will be about the same if you go with a stock replacement. If your so inclined to bump up to 3/4 ton 56s you may get a little more travel. If you swap to the later 62 -63s, you'll see a bunch of gained travel, and more compliant ride. Ive got the 62 rears and 52 fronts. Its pretty flexy. I needed to add a sway bar. Sometime in the near future, I may add a couple of 3/4 ton leaves to the rear to get the load capacity back up a little.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
who sells them?
![]() Join Date: Feb 2004
Pictures?
Yea we need pictures of that beast...
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
Talk to http://offroaddesign.com/ even if they don't have them listed they can get a lot of stuff.
I need to figure out how to post pictures.
photobucket.com its free sign up click upload then drag and drop the picture there.To post it on any forum the img link copy and past it in the forum
![]() Join Date: Dec 2012
Click on <go advanced>
then <manage attachments> then <choose file> click on <upload> quick and easy. I like photobucket and the like but if you close the account or change anything you loose the link.....ever search for a topic and see a post and you see no photo or photo link bad etc???? that is why I upload in forums. Good luck and will keep track of your progress...
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Mine were take offs. Front 52s came from the rear of a 73-74 C10. Rears came off of an 07 Silverado. Front spring mounts were DIY4x4. Rear/ rear hangers were DIY also. Rear / fronts were ORD.
As far as stock length lift springs, theres a bunch of companies. Deaver comes to mind. Theres also Superlift, Rancho and a bunch of others that I really can't comment on BC I don't have much experience with them. Yes^^ Yes x2^^^
#11 | |
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Off Road Design - Nice well built stuff.
DIY4x4 - Nice extremely well built stuff that could be confused with parts from an M1 Abrams.
#13 | |
