Old 04-09-2017, 11:37 AM   #1
3drburb
Re: 78 downlow-littledough
I was wondering where you were going with this after seeing some of the earlier post then checking out your badass dually.
I will take out my notepad pull up a chair and sit in class for this one, watching you do what you do, build new boxes.
3drburb is offline   Reply With Quote
Old 04-09-2017, 08:24 PM   #2
cooperhw
cooperhw's Avatar
Thanks 3drburb,
I might not be the brightest bulb in the box, but I sure as heck can usually get there from here. Just don't have much quit in me.
I was a carpenter for many years before I became an inspector. I usually just try and follow a logical path on how to cut something apart and put it back together as strong as possible.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 04-09-2017, 08:34 PM   #3
cooperhw
cooperhw's Avatar
Didn't get much done today on "downlow-littledough". Had to drive out to my work (bout 80 miles round trip) and pick up my semi-donor 78 pickup. Just a cab, long bed, and front and rear end. I plan on using the a-arms of it as well as some of the other stuff I need. gonna cut the frame down and make a pickup bed trailer and try to peddle it. It's got a real nice cab too. Probably dump it as well after I get some pieces off it.
Too bad you guys in the rusty world are so far away. Good cabs are pretty plentiful out here.
Anyhow, I was able to get my outer plates in place. Welded on the edges and one side got it's 8- grade 8, 7/16" bolts. Man, that drilling takes it out of your back. I forgot how hard it is. I want to get all the bolts in place and tightened down before I weld in the inner plates.
Few pics for anyone interested;
Later,
Wayne
