04-04-2017, 11:58 PM | #5176 |
Re: What did you do to your truck today? Chapter II
I got my new Bullet Shaped Center Caps in the mail today.
Wow, it was 2 days from order to delivery! Tomorrow I put them on. I'll post a pic then |
04-05-2017, 04:41 AM | #5177 |
New sway bar, springs, pulleys and a clutch fan. I had to make a .125" stainless shim plate for behind the crank pulley so I could align the belts. It was also a 20" fan trimmed down and balanced, to 18" to fit the stock shroud.
04-05-2017, 06:21 PM | #5178 |
Fix the hole in my firewall. A lot less heat!
04-05-2017, 07:20 PM | #5179 |
You're gonna be in trouble! That looks like one of your wife's "good" wash cloths!!!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-05-2017, 08:16 PM | #5180 |
04-05-2017, 09:09 PM | #5181 |
04-09-2017, 06:51 PM | #5182 |
Looks good .
04-09-2017, 07:35 PM | #5183 |
Firedemon, is that an auto with 3 pedals still, looks like it used to be a std.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
04-09-2017, 07:39 PM | #5184 |
Door art on one side done
04-10-2017, 12:47 AM | #5185 |
Got my 6.0 LS in place and bolted down. Dirty Dingo mounts and cross member..
Very tight fit with the TH350 in stock position...hooked up throttle cable and installed my home pinned harness.
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
04-10-2017, 12:51 AM | #5186 |
At the body shop.
Changed door seals, hated the glue mess and crappy fit.
Ordered the push on style for GMCpauls.
" That didnt make it any newer " " Dont antique the equipment " |
04-10-2017, 09:39 AM | #5187 |
Door Seals
Based on a tip I read here I bought the ?Dodge Dakota? (correct me if that's wrong) door seals from Steele Rubber Co. and installed them, they're made in America and so have much better quality and won't rot away in two years like the Chinese crappo ones do .
That 6.0 Liter engine looks impressive, I can't imagine feeding it .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
04-10-2017, 06:25 PM | #5188 |
04-10-2017, 09:20 PM | #5189 |
Put new rear end in my Longhorn, a GM 9.5 14 bolt SF, replaced my HO72. Just couldn't find any gears anymore, just Brake pads and bearings. So now I went from 4.11 gears to 3.42, very relaxed Highway driving now-2500 rpm @ 65mph! Plus, it's a lot easier on gas now. Good thing about that axle is there are a ton of different gears out there from 3.20's all the way up to 5.11 or so. If you got all the parts you need, you can do it in one weekend pretty easy.
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
04-11-2017, 08:57 AM | #5190 | |
Take the bolt out on the leaver/push rod side of the pedal use a chisel or screw driver too open up the leaver and pull the pedal out the left side of the assembly .... real easy and leaves lots room for the left foot with the small brake pedal pad. Yesterday I got the dash and doors mostly back together. Put a guage cluster in and a matching wiring harness in instead of the hacked mess idiot lite cluster harness that was in it. Better door handles and door locks that match the ignition key. New dash pad A good heater control, New heater tubes, Cleaned up and lubed inner heater boxes. I gotta find my stash of radio of oe radio knob bucket mounts to put the radio and glove box in yet. And I have a perfect 67 camaro steering wheel to put in too see if i like it better than the oe wheel but the column is coming out today for lube and cleaning. And I'm gonna cut and weld up the heater core mounts so they fit my aluminum heater core.....then the outer heater box can go back in. Hook up the auto meters And put the seat in. I'm kind of digging the multi colored body for now. One day I'll blow it all apart and it will all be black like it orginally was.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
04-13-2017, 09:21 PM | #5191 |
Past 3 Days......
Lower Body Moldings. Assembled the Doors, Vent Windows, Side Glass and window/door mechanisms. Door Handles, Locks, Cab to Door Seals, Mirrors and Window Felts. Getting there! |
04-13-2017, 11:31 PM | #5192 | |
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
04-14-2017, 12:50 AM | #5193 |
Haven't addressed it yet, but walked by the truck this morning and saw a nice little puddle of coolant under the lower radiator hose, which was wet.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
04-14-2017, 07:46 AM | #5194 |
Well, driver's side mirror fell out, that's what I get for putting something that looked like it belongs on a Ford on my Chevy!
04-14-2017, 07:46 PM | #5195 |
That's just your truck telling you not to put ugly parts on it.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
04-14-2017, 07:57 PM | #5196 |
Today, I finally paid attention to what my truck was telling me. For some time, while trying to finish up my build, I have been fighting with door alignment. I managed to get the drivers door (and accompanying spacing) very close to what I wanted but the pass. door has been another story. Ive had the door off and on a few times seeking the correct location before I said screw it and let it sit for a few months. Today I decided to tackle it again and for some reason I suspected the hinges (the new aftermarket hinges). I dug out one of the old hinges and low and behold--they are made differently---only slightly, but they ARE different. Luckily enough I had a spare door in the supply room and even better the "old" hinges were very tight. So, now I have two "new" yet "old" hinges painted and ready to mount tomorrow. God, I hope this solves my issues!!!!!
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
04-15-2017, 06:15 PM | #5197 |
Oil change. Short trip to warm up the oil
04-15-2017, 06:47 PM | #5198 |
Finshed rear brakes and brake lines.
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
04-16-2017, 10:17 AM | #5199 |
Installed new 20" US Mags Ramblers
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
04-16-2017, 05:28 PM | #5200 |
Ramblers are a really nice looking rim.
Mudman.
