Old 03-11-2010, 06:03 PM   #101
lowestsixty7
Re: Project ''Tailor Made'' LOWESTSIXTY7
Started to slowly work on it a little. I will have alot more time after this month. I wont have any more doctors appointments. Will try to post some pics soon.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=317961
lowestsixty7 is offline   Reply With Quote
Old 03-11-2010, 10:02 PM   #102
jlaird
jlaird's Avatar
what are your plans on mounting the gauges? They can't just lay flat because of the angle of the sheetmetal, so you gonna built some type of cups for them to protrude out of? I really like what you did with the dash and thinking about doing something similar. What are you going to do with the passenger side recessed area?
jlaird is offline   Reply With Quote
Old 03-11-2010, 11:43 PM   #103
propaint81
propaint81's Avatar
truck is awesome cant wait to finally see this thing done, if this is the same one i seen at the last year of showfest
ProPaint Collision & Customs
propaint81 is offline   Reply With Quote
Old 03-12-2010, 02:42 AM   #104
lowestsixty7
Propaint81- This truck is actually a different truck then the one you saw at the last year of Showfest. That one is the ''Matt Eye'' truck. That one is still at the shop. Hasnt been worked on in quite awhile. Hopefully we get back on it soon.
Jlaird- The gauges acutally do lay flat on the dash that was made. You can see the gauges very clearly when sitting in the drivers seat. The passenger side is going to get a 7'' screen in it. I have attached some pics of the gauges.
My Build Thread
Old 03-12-2010, 02:18 PM   #105
jlaird
jlaird's Avatar
sweet! thanks for the pics. Hope you don't mind, I did a little photochop! This was along the lines I was thinking for mine. What do you think?
Old 03-12-2010, 02:34 PM   #106
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That's very similar to the way I am planning on running mine..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-12-2010, 02:50 PM   #107
lowestsixty7
Looks Good
My Build Thread
Old 03-12-2010, 04:39 PM   #108
jlaird
jlaird's Avatar
Originally Posted by lowestsixty7 View Post
Looks Good
What metal working tools did you use to do that dash? In one of the close-up shots I see how you bent the metal as one piece and welded the seam on the flat end. Very smart! The extent of my metal working experience are patch panels and I shaved my firewall. I'm a little nervous about cutting my dash out, but hopefully all will go well.
Old 03-02-2011, 08:05 PM   #109
(joey)
(joey)'s Avatar
any new updates?how did you mount the one piece front clip?
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 03-02-2011, 10:07 PM   #110
yunkyarddog
yunkyarddog's Avatar
if i only was .0009% as good
yunkyarddog is offline   Reply With Quote
Old 02-14-2013, 01:53 AM   #111
krazyt
krazyt's Avatar
Any updates on this truck, Did it ever get finished
krazyt is offline   Reply With Quote
Old 11-17-2013, 09:51 PM   #112
DREAMER1
DREAMER1's Avatar
Any updates on this build?
DREAMER1 is offline   Reply With Quote
Old 04-11-2017, 10:45 AM   #113
Hart_Rod
Hart_Rod's Avatar
bump
Hart_Rod is offline   Reply With Quote
