Advice on the gear ratio for 350 vortec with TH350 -
Hi ,
I have a 1964 C10 Stepside - short wheelbase, with 350 5.7 vortec and TH350. Tires are 225/75R15 (28.5"). Current differential is from a 1973 Chevrolet Caprice (350 engine) added to the truck by the previous owner, but I do not know the current gear ratio. It is the 10 bolt, 8.5", 28 spline differential. When I drive on the highway at 60mph, tach is showing around 4000rpm ( What gear ratio would be the best for this engine-trans-tire combo? Thank you all in advance ![]() From: Istanbul, Turkey |
#2 | |
Re: Advice on the gear ratio for 350 vortec with TH350 -
at 4000 rpm with a 28" tall tire, and a 1 to 1 3rd gear (th350) at 60 mph is a rear gear of 5.56 not likely.. you can get a ballpark,, by putting the rear axle of the car on jack stands.. mark the driveshaft. and mark the tire put the car in neutral , car not running.. and turn the driveshaft until the tire makes one full turn/rotation. counting the # of times the drive shaft turned.. it turns 3 and 3/4 times.. most likely have 3.73 gears 3 and 1/5th 3.23 just over 3 3.07 3 and just under a 1/2 3.42 little over 4 times. 4.11 etc. |
![]() Join Date: Apr 2014
http://www.wallaceracing.com/calc-rgr.php
Calculate Rear Gear Ratio for given MPH, RPM and Trans Gear Ratio When I plug in the numbers but in the trans gear ratio I put the th350 2nd gear ratio of 1.52 I get a more normal 3.66 and with the speedo being off, your tach being a tad off.. and me using 28" tire not 28.5" it get close to a g.m. 3.42 rear gear.. So.. let me ask, are you sure it's going into high gear.. and not going down the highway in 2nd |
![]() Join Date: Mar 2003
Go with a 3.08
Since it is a mix of parts, it is very likely that the speedometer gear unit in the transmission isn't correct for your setup and giving a wrong speed reading. Get a chase vehicle or gps unit and confirm your speed.
Active Member
![]() Join Date: Jul 2007
Agree with a 3.08. That's what I have on my 69 and it was a decent street ratio and also had no trouble pulling an 18' trailer with a full size tractor and shredder (no tall hills).
As for the ratio on your truck, in some cases there's a number stamped on top of the passenger side axle tube. Years of grime may have covered it so use a wire brush to clean it if it's crudded up. I found removing the passenger side tire gave me a better view of the number on mine.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Stock engine? 3.08's if you don't want it to pull very much comfortably, around a 3.36 or maybe a 3.42 (popular in the 90's 1/2 ton 2WD trucks) if you want it to tow a little better.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
driving is in my blood
I wouldn't do anything steeper then 3.07's, you don't have overdrive. You'll still be at 3k running 80mph with 3.07's.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
| Bookmarks |
| Tags |
| differential, drivetrain, gear ratio, th350, vortec |
