Old 04-13-2017, 08:33 AM   #1
ab_70chevy
Mcgaughy drop spindles install question
I'm finally making the switch to drop spindles but I was wondering if I would need anything else to install them. I already have the disc brakes on the truck and I know with some of the cheaper spindles, they require different ball joints. Is this the case with McGaughys, or can I just do the switch and roll. I'd appreciate any help
Thanks fellas,
Andrew
ab_70chevy is offline   Reply With Quote
Old 04-13-2017, 10:18 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Mcgaughy drop spindles install question
What year is the truck and what years are the drop spindles for?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-13-2017, 11:57 AM   #3
ab_70chevy
'70
Old 04-13-2017, 01:26 PM   #4
Fldawg
Fldawg's Avatar
i just ordered ball joints for a 70, worked on mine
"Send in the clowns the goats are loose"
Fldawg is offline   Reply With Quote
Old 04-13-2017, 09:13 PM   #5
Kennuck
Kennuck's Avatar
I used Western Chassis 2.5 drop spindles on my '70 they fit up with the '70 ball joints and tie rod ends.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 04-13-2017, 09:52 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
You have to order spindles to match the year of ball joints and outer tie rods you are using.
They are sold by the following years:
60-62
63-70
71-72
73-87 light duty
73-87 heavy duty.
Keith
Convert to disc brakes.
Old 04-13-2017, 10:29 PM   #7
57larry
I have a set of 2 1/2 drop on mine. bolt on a 72 front end
57larry is offline   Reply With Quote
Old 04-14-2017, 03:57 PM   #8
ab_70chevy
Thanks fellas, I'm ordering them today!
