Old 04-10-2017, 06:16 PM   #1
billrobbobjo
billrobbobjo's Avatar
Chains
Has anyone done anything else to their chains beside putting rubber sleeves over it? I like the look of it hanging without the rubber tube over it. Has anyone tried dunking them in like Flex seal or something? I heard plasti dipping them but people say they wear out. Trying to prevent clear coat scratching! thanks
1957 Short Box
http://67-72chevytrucks.com/vboard/s...d.php?t=671001
1969 GMC 3/4
billrobbobjo is offline   Reply With Quote
Old 04-10-2017, 07:12 PM   #2
HUSSEY
HUSSEY's Avatar
Re: Chains
These leather covers are cool...
http://67-72chevytrucks.com/vboard/s...d.php?t=637480
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 04-10-2017, 08:01 PM   #3
billrobbobjo
Re: Chains
Ya i was looking at those, they look really nice
1957 Short Box
1969 GMC 3/4
Old 04-10-2017, 10:31 PM   #4
nvrdone
Re: Chains
how about using some clear vinyl tubing to cover them ?
nvrdone is offline   Reply With Quote
Old 04-10-2017, 10:43 PM   #5
1project2many
Re: Chains
I once saw some plastic chains on a tailgate. They looked ok from 20 feet away...
1project2many is offline   Reply With Quote
Old 04-10-2017, 10:59 PM   #6
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Chains
Plastic chain?! Puhleez.
I posted a thread about alternate ways of covering chains awhile ago so my new paint won't get chipped. In my experience the clear tubing looks cloudy or yellows over time - ugh.
I wouldn't mind ordering these and I like them as is but I'd prefer something simpler, no two tone. Since I'm a baseball fan, maybe something incorporating a baseball style stitch but nothing over-the-top with colors of my favorite team or anything like that. Just subtle.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 04-11-2017, 02:27 AM   #7
mdpaulson1
mdpaulson1's Avatar
Re: Chains
I've scene clear vinyl/plastic coating they use as a rock guard that seems to hold up from chain abuse. Very simple and easy fix. Rhinoskin, trimbrite, and 3m are the first that come up on google
mdpaulson1 is offline   Reply With Quote
Old 04-12-2017, 12:15 AM   #8
mr48chev
mr48chev's Avatar
Re: Chains
I've cut down bicycle innertubes and slipped the over the chains on more than one occasion. Not all that pretty but they keep the chains from scratching the
My ongoing truck projects:
Old 04-12-2017, 01:26 AM   #9
JimDirt
Re: Chains
Has anyone considered Vinyl coated cable ??
i was thinking of doing this instead of the chains on my 58 , just buying the cable lengths i need , then soldering or welding a hook on them , similar to what is on newer trucks , except they hook on instead of being affixed to the tailgate , that way its covered so it wont scratch up the paint banging around , and its not the same old chains you would expect ..... yes/no ??
JimDirt is offline   Reply With Quote
Old 04-12-2017, 01:38 AM   #10
dsraven
Re: Chains
if you decide to use cable you could get a hydraulic shop to press on the ends and it would look pro. phone around first but a lot of those hose shops also make custom brake flex lines with stainless outers (I had some custom built for my motorcycle) and they also make winch cables and park brake cables so they would likely have the tools and supplies to fab up the ends. also, maybe a set of tailgate cables from a newer truck could be fitted, they already have the ends and are coated.
Old 04-12-2017, 04:06 PM   #11
OrrieG
OrrieG's Avatar
Re: Chains
That is what I used, heavy thorn proof ones. Need to cut a slot at the middle which is bottom in hung position to let the water out so the chains do not rust. Even then they can rub side to side working on the paint. This time I went with inside latch and cables.
Old 04-12-2017, 06:10 PM   #12
mongocanfly
mongocanfly's Avatar
Re: Chains
Although I do like the chains I'm going to be using the 2 piece tailgate link supports the mar-k sells on mine..just can't stand the beatup paint from the chains
Old 04-14-2017, 05:56 PM   #13
1project2many
Re: Chains
[QUOTE=Dan in Pasadena;7912449]Plastic chain?! Puhleez.[quote]
It was hilarious! It was on a truck shell in front of an ice cream stand. It looked ok from the parking lot but as I approached I knew something was off. Fake chains for a fake truck. Too much.
I ordered OE covers for mine years ago. Stepside trucks made into the late '80s had 'em but maybe NLA? It took a bit of work for me to find the numbers even back then.
