Closed Thread
Old 04-16-2017, 08:05 PM   #5201
3rdGen.c10
3rdGen.c10's Avatar
Cool Re: What did you do to your truck today? Chapter II
Built some sway brackets to match the width of the 3rd gen camaro rear sway bar for the rear of my 67 c10. Also fabbed up some exhaust clamps with a wider base for the bushing to mount it to the axle.
1967 c10 stepside 6.0L 4L80E
3rdGen.c10 is offline
Old 04-16-2017, 10:22 PM   #5202
Caustik
Caustik's Avatar
Gave the neighbors a break from the hammering and grinding, spent some time with a tape measure taking notes down for a the 4 link and step notch.
Caustik is offline
Old 04-16-2017, 11:57 PM   #5203
ghalperin
ghalperin's Avatar
I'm about ready to install the same sway bar in my 67.
What size muffler clamps did you use? What did you use to make the frame brackets? Do you have any installed photos?
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Old 04-17-2017, 12:02 AM   #5204
ghalperin
ghalperin's Avatar
That's funny. I also gave my neighbors a break from hammering and grinding, instead I ran the pressure washer all day.
Glenn
Old 04-17-2017, 12:06 AM   #5205
wpavlis
Replaced my rear shocks. I also cleaned up some rust I found behind my master cylinder when took it off last week.
wpavlis is offline
Old 04-17-2017, 02:01 AM   #5206
3rdGen.c10
3rdGen.c10's Avatar
I used 3" clamps and I welded a piece of flat stock to the top of the clamp to give the bushing more surface to sit on. I made the sway bar brackets from 3/16 wall 2" square tubing that I had laying around and some flat 3/16 pieces and just cut and welded and drilled to make these. They put the end link holes an inch further out on each side to make the correct width for the bar without having to use a spacer like you would with the factory 3rd gen camaro /firebird mounts. It's not installed yet because I painted them so they're drying but I should have some installed pics posted Tuesday.
Old 04-18-2017, 08:11 PM   #5207
SoCoC10
SoCoC10's Avatar
Freed a truck from paint jail.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 04-20-2017, 08:15 AM   #5208
3rdGen.c10
3rdGen.c10's Avatar
Got the rear sway bar brackets fabbed up and painted. Final install.
Old 04-20-2017, 08:58 AM   #5209
ghalperin
ghalperin's Avatar
Looks good. Thanks for sharing.
Glenn
Old 04-20-2017, 09:22 AM   #5210
Wortham48
Wortham48's Avatar
Got my Mcgaughy's 4.5/5 kit installed and all new ball joints. Rear tires are rubbing a little (20x10) but other than that it rides so much better than before with all new suspension components!
Wortham48 is offline
Old 04-20-2017, 07:13 PM   #5211
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Got the Booster /Master combo I bought from Frank's Pickups installed on the truck. Works great.
http://67-72chevytrucks.com/vboard/s...d.php?t=581862
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 04-20-2017, 07:29 PM   #5212
66clow
66clow's Avatar
I can now drive at night and in the rain. New harness and wipers.
See any problems with this harness?
66clow is offline
Old 04-20-2017, 08:15 PM   #5213
NoStopN
NoStopN's Avatar
That looks like my high quality work.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 04-20-2017, 10:25 PM   #5214
mild68
mild68's Avatar
I'm not doing any body work. I put the cab on another Chassis I had set up yesterday. I also got the wire harness laid out n hooked up. I ordered some parts today.
mild68 is offline
Old 04-20-2017, 10:31 PM   #5215
rustytruck50
rustytruck50's Avatar
Replaced the voltage regulator and park bulbs....chipping away slowly but surely
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline
Old 04-21-2017, 10:01 PM   #5216
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1492826393
Installed 1-1/4" sway bar in the 67.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline
Old 04-21-2017, 10:02 PM   #5217
427Carl
427Carl's Avatar
wow.... nice job!!!!
88 Suburban Silverado (original 48,000mi)
99 GMC Z71 stepside
01 GMC 2500HD crew (Texas truck)
07 Chevrolet Suburban LT
84 Chevrolet S10 short box 355 V8
427Carl is offline
Old 04-21-2017, 10:05 PM   #5218
Canuckvetter
http://67-72chevytrucks.com/vboard/a...1&d=1492826636
Install new carpet and freshened up door panels
Old 04-21-2017, 10:08 PM   #5219
Canuckvetter
http://67-72chevytrucks.com/vboard/a...1&d=1492826818
Installed bucket seats.
Old 04-21-2017, 10:10 PM   #5220
Canuckvetter
http://67-72chevytrucks.com/vboard/a...1&d=1492826952
Installed Chevelle wheel and freshened up gauges.
Old 04-21-2017, 10:55 PM   #5221
Already Gone
It looks like your truck didn't have a sway bar before. You will notice an immediate difference in the feel and handling of your truck. The front sway bar install is one of the best bang for the buck upgrades you can do to one of these trucks.
Old 04-21-2017, 11:47 PM   #5222
Canuckvetter
Yes for sure "Already Gone"! It was so weird to take the on ramps in Edmonton. So use to anticipating the roll. I love how it feels. Have a 1" front sway bar that I will be installing in the other truck.
Old 04-22-2017, 01:52 AM   #5223
Already Gone
I don't know if you purchased the front sway bar new but there is cheaper alternative that works really well. Any 1973/1987 C30 or GMC 3500 truck has the 1 1/4 inch front sway bar. Some of the heavier GVW C20 and GMC 2500, like the camper or trailering special ones have the 1 1/4 front bar too. Get one from a wreck in a salvage yard, usually 40/60.00 and buy a new set of bushings for it and use it.
Old 04-22-2017, 09:52 AM   #5224
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Just curious because I have a sway bar to put on; Did you put the sway bar on at ride height? How/Where did you jack it up at?
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline
Old 04-22-2017, 11:24 AM   #5225
ChaseBBC
ChaseBBC's Avatar
got the bed off and took apart.
ChaseBBC is offline
Closed Thread
