04-03-2004, 06:41 PM | #1 |
Where's my beer?
Rear window not going up
As the title says, is not going up!! and I'm pissed is been raining all week here and the inside is soaking wet I did a search and there's supposed to be a rear door close switch (which I didn't find), but my problem lays in that I need to get this window up asap because we're expecting more rain, does anyone know how to roll the window up manually? I already pulled the inner cover but I can't reach the window mechanism since the glass is on the way (I rolled the window up manually before but it was only halfway down)
Any input is appreciated. Thanks.
Paul How do you make the invisible, visible?.........You take it away. |
04-04-2004, 11:32 AM | #2 |
Big Block Blazer
Just be careful when you get your Finger's around the Regulator, it will clean them right off your Hand.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys] |
04-06-2004, 09:48 AM | #3 |
I have the opposite problem, mine won't go down. The switch is inside the rear door, take the access panel back off. Follow the wires from the motor towards the passenger side where the locking latch is. You will see the switch, I'm not sure if you can get to it with the window down. Goodluck
