#26 |
Re: Next up: Parting 79 1/2 ton 2wd
pm sent
#27 |
How much for the Emergency brake and as much of the cables as you can? shipped to 98596? Picture of components?
Retired and too busy to work. |
#28 |
Sorry, the e brakes were no good.
Thanks, Ray |
#29 |
pics for madcow
#30 |
I will take the bezels and hinges.
Now how much for you rear cab trim shipped? |
#31 |
payment sent for bezels and hinges
#32 |
Is the other set of hinges any good? Mine pins are shot and hinges may be a lil out of whack..Let me know
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
#33 |
I have 3 rear cab trim pieces and 1 set of cab corner trim. the corner trim has some dings and I can put them in with your bezels. The best out of the 3 is the one with black paint (bottom one), the middle one is the worst. The best one with yellow paint has a gauge on one end and a dent on the other end. Shipping will cost more than the part. $40 shipped. Here's pics
#34 | |
Thanks, Ray |
#35 |
Im still interested but the truck out of commission right now so I wouldnt be able to pick them up at greyhound.....Figures I would push the speedo gear into the transmission replacing the housing lol.....
Sounds fair....I dont have the money right now but If you have them still next fri Ill grab the hinges.... Thanks!
#36 |
$40 shipped. I will take a setup. You say the middle one is the worst? Pictures show it as the nicest. But if you say the black one is the best I will take the best. The paint colour does not matter to me. Just the aluminum shape, as I will be striping it. I will take a set of good cab corners. Do you have all clips to go with it?
#37 |
payment sent for cab trim
#38 |
Hey RAY! I just got a refund in my account so I have the money! PM me your paypal info and Ill send you the money for the hinges..They will fit a 78 GMC right?
#39 |
Not the axle part, this part?
#40 |
I will check for the release rod late Sat. or Sun.
Thanks, Ray |
#41 |
Not just the rod, the whole assembly, the part you step on, the cable it attaches to, the cable that feeds thru the floor to the split under the truck.
#42 |
Chris
that small steering wheel for sale? the one in the pics? if so what's the price on it?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
#43 |
oldcouple...I have the assembly for $26 total shipped to WA. I do not have a good cable.
benoit454...$32 total shipped to WV for the wheel, hub, and hardware. Thanks, Ray |
#44 |
madcow
#45 |
more
#46 |
this may be a silly ? and it may be a lot bigger part then i know but on the front of the truck their is a solid bar that goes across below the battery tray and the inner fender connects to it...Is that replaceable????? also is it go across the hole front or just a 2 piece type setup??? If so do you have a good one?
#47 |
That bar is part of the core support. You need to replace the entire support or weld in a patch.
#48 |
How much for the long bed?
#49 |
Whats up with the door panels, dash pad, or seat?
#50 |
This truck is long gone, but I have some good beds here for $200.
I have some door panels, but most are sun chapped. My dash pads have some cracks. I have a good blue vinyl seat for $200 with no rips if you are interested in that. Thanks |
