Old 04-20-2017, 11:01 AM   #1
Pinchecharlie
Pulled axles on a 65 12 bolt question
I pulled my axles last nightvsnd when I pulled the large pin in the rear end (the one that keeps the axles in place) I noticed it was a bear to get out. I've seen guys pull them with magnets. Had to really reef on it with a screwdriver through the hole back and forth la la la. Should I be concerned? Easy visibly bent but I did not take any measurements either. Thanks Charlie
Pinchecharlie is offline   Reply With Quote
Old 04-20-2017, 11:23 AM   #2
Shady Rascal
Shady Rascal's Avatar
Re: Pulled axles on a 65 12 bolt question
If the crosspin is galled or damaged, they are cheap and easy to get.
Yukon Gear part number YSPXP-038
https://www.yukongear.com/productdet...spx?ProdID=504
Summit has them in stock for 14 bucks.
https://www.summitracing.com/parts/yga-33406
Shady Rascal is offline   Reply With Quote
Old 04-20-2017, 11:52 AM   #3
Pinchecharlie
Nice thank you very much!
Old 04-20-2017, 11:53 AM   #4
Shady Rascal
Sure
