04-04-2017, 07:48 PM | #1 |
radiator support help
So I have a radiator support that someone had cut off the headlight cups on. Does any know why someone would cut these off and is there someone I can just buy the headlight support part? Or know of a way I could make something so my light sit right?
04-04-2017, 10:11 PM | #2 |
Re: radiator support help
Why would someone cut them off????
I think you are going to have to find a new core support or rescue the headlight mounts from another core support.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
04-05-2017, 02:45 AM | #3 |
I do not know...
well anyone have a crappy radiator support with good light dishes lol |
04-05-2017, 07:41 AM | #4 |
The cup that the headlight sets in is just mounted with 2 screws and a spring. Take a picture so everyone understands the problem. I will have to look but probably have just the cups.
04-05-2017, 04:18 PM | #5 |
Was it a GMC support? If so, someone may have removed the headlight brackets so they could use the support on a chevy.
Good luck finding some, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
04-05-2017, 11:53 PM | #6 |
04-06-2017, 06:44 PM | #7 |
Pictures attached
04-06-2017, 06:45 PM | #8 |
04-06-2017, 06:57 PM | #9 |
Okay, 2 things I see.
One is yeah, someone cut the jimmy part off so they could change to a chevy grill. Do you have a grill? Is it the chevy or the gmc grill? Check this thread, especially post #5, it talks about changing the gmc to a chevy support by removing the parts your's is missing. http://67-72chevytrucks.com/vboard/s...d.php?t=143068 Second, the fenders are 69-72 chevy fenders, not GMC fenders. You do have the 69-72 gmc hood latch assembly. Not sure about the center grill support. Maybe you should just run a 69-72 chevy grill... Good luck, Rg
04-07-2017, 12:16 AM | #10 |
I have a Chevy grill. I did not know the hood latch was different. Will I need to swap the hood latch?
04-07-2017, 09:14 AM | #11 |
I'm not sure, the latches are the same except the GMC handle is shifted off to the side to miss the center part of the gmc grill. If it interferes with the Chevy grill you will need the chevy hood latch.
I'm curious, was this truck together or apart when you got it? I'm asking because I can't see how the chevy headlight buckets are going to go on there with out some extra holes (square ones at that) being in the radiator support. Rg
04-07-2017, 11:16 AM | #12 | |
Posted via Mobile Device |
04-07-2017, 11:27 AM | #13 |
I have a rad support I can remove everything I will get pictures tonight.
04-07-2017, 11:31 AM | #14 | |
Remember, trucks are fun, I have to keep repeating that so I don't sell mine. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 04-07-2017 at 11:48 AM. |
04-07-2017, 02:20 PM | #15 |
04-07-2017, 02:23 PM | #16 | |
Yea my worry with fabricating one would be trying to position it right. This is why I wanted to get a pair and just weld or bolt on like you suggested. Yea I had some choice words when I found the zip tied on lights. Some people just never do stuff right... |
04-08-2017, 09:01 AM | #17 |
Here is what I have I will nee d to at least remove the grill to cut them off. 25 ea. plus shipping I would think I could get them in a medium flat rate for 18 let me know if still interested.
04-09-2017, 02:58 PM | #18 |
Have them removed they will fit in a medium flat rate.
04-16-2017, 02:04 PM | #19 |
It appears that those dual cups are the only thing different about about the GMC/Chevrolet supports. I always thought they were much more different from each other. I have some sources that I'll check with to see if I can get you some. It's all goes back to GMC discrimination..
1972 GMC Jimmy 6.0/4L65 1972 Chevrolet long bed 1/2 ton |
04-20-2017, 11:16 PM | #20 |
I was looking on ebay they have 7 inch round headlight mounts that would probably work too. Here is the link http://m.ebay.com/itm/Pair-Mounting-...%257Ciid%253A1
04-20-2017, 11:56 PM | #21 |
Well the 7 inchers won't work with the GMC trim pieces as they are 5 1/4". Are you gonna use a GMC grille or Chevrolet?
