Any center link gurus out there?
Ism trying to swap front end parts from a donor 84 to my 65. Well the center link is bent and I can't seem to find one? Wondering if anyone knows of an compatible one? 4wd? S-10 ect..? I know from the fact section I can use an adapter tie rod adjuster sleeve and use the 65 steering linkage but since it's apart I would like to replace with new parts . One way or the other I will replace with new but I've read the late model steering linkage is more desirable? Thanks Charlie
Should have mentioned that I've all ready ordered late model spindles . Thought I could still use the brakes ect.. guess I could send them back but seems like a hassle. |
Re: Any center link gurus out there?
You will have to also remount the idler arm if you use the later steering link. Not a big job but you need to keep the geometry the same.
60-66 Nut
If you use everything from your '84 donor truck including the entire steering linkage, that simplifies the whole conversion. That is what I always recommend. As already mentioned, you will have to drill holes to mount the later model idler arm. Not a big deal.
If I am not mistaken that center link is considered a non wear item as the pivoting joints are in the idler and pitman arm so the aftermarket is not liable to make one as no demand for it. If you still have the original one just check the taper in the holes and clean it up, paint it and use it.
its bent. thought i mentioned that sorry. thanks for the replies though
Never Ending Projects
Yep, I know how that goes. This is what happens when someone tries to pull the truck from the center link... I happened to find a local guy selling one.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#7 | |
![]() Quote:
Sam |
