Old 04-23-2017, 04:13 PM   #1
MXC_Rider
Question Found in my door (72)...What are these?
Hey guys, been a member for a while now and finally picked up a '72 blazer a few weeks ago. Im starting to do some of the simple things such as rewiring radio, fixing headlight wiring, trans rear seal etc.
Right now i'm replacing the door locks and when i pulled everything apart i found these two brackets at the bottom of the door just lying there. One looks like it may be original with surface rust, and the other looks like a replacement???
Any idea what these are?
THANKS!
M
MXC_Rider is offline   Reply With Quote
Old 04-23-2017, 04:27 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: Found in my door (72)...What are these?
Mirror backing plates?
DPowers is offline   Reply With Quote
Old 04-23-2017, 04:35 PM   #3
Rem701
Definitely backing plates for the rear view mirrors
Rem701 is offline   Reply With Quote
Old 04-23-2017, 04:51 PM   #4
MXC_Rider
I assume you mean "side view" ?
just went and checked and the bolt hole pattern looks like it should fit. Neither the drivers side or the passenger side have the backing plates installed. Guess i found something else i gotta do now.
Thanks for the info!!!
Old 04-23-2017, 04:55 PM   #5
my56chevytruck
my56chevytruck's Avatar
BINGO, side view inner door mirror supports.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
