09-02-2010, 01:15 AM | #1 |
Why does my 305 tbi idle so high???!!!
On my 87 its got the stock 305 tbi in it, I've replaced pretty much everything sensor related on it including the throttle body base gasket and it still idles at about 1700 when I first start it up and stays there for at least 10 minutes or so then slowly goes down to about 1200 when its all warmed up could it be timing? Theres no check engine lights on, its just getting on my nerves and wondering if anybody else had this problem on a tbi motor. If anybody can chime in and let me know what to look to do that'd be awesome.
09-02-2010, 02:19 PM | #2 |
Re: Why does my 305 tbi idle so high???!!!
use carb spray to check for vacuum leaks.
Your IAC (Idle air control) valve could be stuck with the plunger retracted. A bad coolant sensor can make the computer think the engine is cold causing a high idle. Does it seem to run to rich? Is there any other symptoms other then the high idle From the Auto Zone site on TBI rebuilding The easy-to-replace parts that wear out in TBI systems are the same parts that wear out in carburetors: Gaskets, o-rings, and seals, all of which are sensitive to time, fuel, and extreme changes in temperature. Since there are less moving parts involved, rebuilding a TBI system is easier than rebuilding a carburetor. If you have ever built a model airplane, then you most likely can rebuild a TBI system. Armed with a TBI rebuild kit, the task can be performed in just one afternoon. The fuel injectors themselves, however, should be tested and cleaned professionally or replaced if problems are suspected. Finally, as the complexities of TBI systems vary by manufacturer, the first step to a successful TBI system rebuild is consulting a service manual. |
09-02-2010, 02:32 PM | #3 |
Doesnt seem to be running rich at all, coolant temp sensor been replaced twice due to me thinking its that as well, the IAC I've went through three of em. It seems to be a vacuum leak somewhere that I can't find. I do work at a shop so I just ordered a smoke machine so I can search for a vacuum leak, when i drove it this morning after a little bit of driving it idle'd at about 900 so seems to be going down after I didn't repalce a thing on it
09-02-2010, 02:42 PM | #4 |
vacuum leak yes
09-02-2010, 04:04 PM | #5 | |
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
09-02-2010, 04:59 PM | #6 |
Hey rfmaster I just tried that IAC reset and man did it work beautifully then after driving it and shuting her down then decide to start up right back up to 1700 rpm or so do you think my IAC is a bad one again? Still have not seen any vacuum leaks either went through 2 cans of spray already as well. Im guessing my truck may be possessed possibily ???
09-02-2010, 05:37 PM | #7 | |
Other possibilities include harness - IAC connector intermittent, ECM driver circuit intermittent. //RF
09-02-2010, 05:37 PM | #8 |
valve cover gasket? i have had that problem.
09-02-2010, 07:54 PM | #9 |
Ok so I replaced the IAC didnt change anything on idle. Did the reset and achieved beautiful idle once again but when I shut it off and then restart it goes right back up. So now I have 2 new IAC's and one of the original ones that was in it did the reset on all 3 of em and got a great idle but once restarted its nice and crappy again. It's like the computer is not remembering what position the IAC was at once restarted correct? Do you think my computer could have a problem? And valve cover gaskets are new due to having a leak like last month.
09-02-2010, 08:45 PM | #10 | |
During engine cranking ECM will move IAC into intermediate position (110 to 120 steps) depending on temperature. This will result in initial high engine RPM flare up - to prevent cold engine from stalling. Once engine is running ECM monitors RPM & coolant temperature (CTS) and slowly step IAC down restricting idle air thus reducing idle speed (about 25 to 12 counts). This is a simplified explanation of how IAC is controlled. If ECM receives false CTS reading (CTS disconnected = -40C) - i.e. very cold coolant it will maintain high idle around 1100 RPM. Short A+B and and observe SES light - if there are no pending DTC you should see SES blink code 12 three times and repeat. If there are pending DTC they will follow code 12. You may have bad CTS - but pull codes first to be certain. Does your engine run rich??? //RF
09-02-2010, 10:09 PM | #11 |
RF you my friend are the best! So I thought I ruled out it being the CTS. So I took out the newer one put one I had laying around at my shop and wow starts up idles nicely seems like problem solved!!!!!! I feel as if I owe you a beer sir thanks alot bro for helping me diagnose my problem.
09-02-2010, 10:58 PM | #12 | |
BTW, I am not a mechanic, but I like to to modify TBI, since this early EFI system is easy to troubleshoot and can be adapted onto just about any internal combustion engine. Keep on trucking.... //RF
09-02-2010, 11:29 PM | #13 |
Yeah I drove it for a little bit does seem to have a miss im just gonna go ahead and repalce the plugs tomorrow, its about time for some anyway. Any other tricks for this TBI setup that I need to know. Good gap for plugs I'm gonna throw in tomorrow? Is the throttle body spacer really worth it in your opinion? I am new to this kinda of setup I'm used to carbs. Thanks
Josh |
09-03-2010, 02:04 PM | #14 |
My R30 is having similar symptoms but also has a burned out check engine light. Got a little list of stuff to mess with this weekend. I'm going to try to reset the IAC since I've already replaced the CTS.
I really appreciate the insight on this stuff guys. I love the truck and want to try to keep the TBI on it rather than convert to carb. Hey RF, where are you in OC? Thanks, Sean
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
09-03-2010, 07:00 PM | #15 | |
1) Improve fuel volume and pressure. Stock TBI can run with as little as 6 PSI - it will run, but very poorly. Install stiffer FPR spring and adjsutable FPR (from Jet). I like to run my TBI in the 15 to 16 PSI range. Higher pressure improves fuel atomization resulting in better combustion. In my conversions I run 40kV coil and gap plugs at 0.045". 2) I run 1" spacer on my Holley 300-66 intake - keep in mind that stock fuel lines will not clear Holley projection intake without spacer. Spacer improves throttle response. 3) I run headers and true 2-1/2" dual exhaust system on my rig. It sounds nice (as for performance improvement it is hard to tell since I did a lot of work over time) 4) Custom tune - I tune my ECM. So that any flat spots are taken care of. //RF
03-13-2011, 04:28 AM | #16 | |
03-13-2011, 05:25 PM | #17 | |
//RF
03-14-2011, 01:30 AM | #18 | |
03-14-2011, 10:20 AM | #19 | |
10 minutes with bat cable off is a bit excessive - all it takes about 10 to 30 sec for ECM to loose its memory when battery cable is removed. high idle speed can be due to a vacuum leak - these usually form between intake and TB especially if that gasket was never replaced. Another reason for high idle is incorrectly set base timing - which must be set EST connector open engine idling around 625 RPM or less. This when you can adjust minimum idle screw. //RF
04-27-2017, 04:45 AM | #20 |
I have an 87 GMC 305 with TBI and a 87 Chevy 350 with TBI about 8 months ago my idle speed went up so high that it darn near knocked out the U-Joints when shifting in an out of gear as I was doing a tune up and inspection of related components, I found that my o2 sensor was broken off just above where you put the wrench to remove it. I replaced the sensor and my Idle went back to normal so I concluded that the idle was high because of the 02 sensor controls air / fuel mixture to burn off excess fuel for emissions . I may have been wrong about my conclusion because my idle went backup to an unacceptable level and after doing a new new tuneup you know (plugs, cap, rotor, wires, filters, fuel and air and o2 sensor my idle did not go down this time. So I will follow the leader and do the things listed above to see if that might be my problem. thank you all for the support I get from this sight! I will get back with you when I find out what my solution is. or more questions if I dont
