Old 04-27-2017, 11:30 AM   #1
Rick4076
drain
So I lowered the front of my 70 C10 and now of course the bed fills with water on rainy days. Does anyone have a good idea for a drain that looks half way decent I don't want to drill a big hole in the bed?
Rick4076 is offline   Reply With Quote
Old 04-27-2017, 12:32 PM   #2
biketopia
Re: drain
I thought the factory floor had to holes in each front corner for that reason. Just drill some small holes there, nothing much, the water will drain as long as you keep the holes clear no mater how small you have em.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is online now   Reply With Quote
Old 04-27-2017, 12:52 PM   #3
Alex V.
Alex V.'s Avatar
Re: drain
I'm with biketopia. My '85 has a hole in each front corner - even if it didn't come that way from the factory I'd consider it a reasonable "update".
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 04-27-2017, 01:00 PM   #4
biketopia
Re: drain
I just took my bed apart two weeks ago or I'd go verify. I know my 03 has small 1/8' inch holes in each groove at the front of the bed.
Old 04-27-2017, 01:15 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
Re: drain
The factory 70 bed on my 72 has holes in the front corners
Tyler
Old 04-27-2017, 01:34 PM   #6
dfwright
dfwright's Avatar
Re: drain
Factory 72 bed has holes in the front corners
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 04-27-2017, 03:45 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: drain
Bed liner? My truck (1972 GMC) has holes in the front of the bed too.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-27-2017, 04:05 PM   #8
Rick4076
Re: drain
looks like I'll drill a couple holes. Thanks all!
Old 04-27-2017, 05:05 PM   #9
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Re: drain
Just let it fill up and invite some "friends' over.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 05-01-2017, 01:41 PM   #10
b.sharp
b.sharp's Avatar
Re: drain
The factory drains are not round wholes. they are about three ribs from the edge. They are a bent down section of rib on the floor and clog very easily with dirt. You can run a stiff wire or a nail through them to relieve the debris that is clogging the whole. That should fix your issue. I have to do mine a couple times a year from dirt and leaves clogging them up.
b.sharp is offline   Reply With Quote
