Putting 4 speed manual behind SBC, will it hold up?
So I have a 1970 service truck that I am likely to buy and part out, it has an inline six and a 4 speed manual, I am thinking about taking out the TH400 from my 1972 and putting in the 4 speed manual. Curious what will be involved short of cutting a hole in the floor and installing a clutch pedal? Also how stout are these transmissions? Will it hold up behind a 375hp 350?
1972 C10 - It might be old, but it's not slow |
![]() Join Date: May 2013
Re: Putting 4 speed manual behind SBC, will it hold up?
pretty sure those transmissions were rated for like 900 ft pounds , so a smallblock should be no problem
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#3 | ||
"I ain't nobody, dork."
Probably an SM420 or SM465 which are pretty stout. But they are granny-low 4 speeds. So if you're looking for any performance... I'd stick with the TH400.
Gary
Remember it's effectively a three-speed transmission with a single-gear low range. The first gear is the "poor man's transfer case" in a way.
I've always started in 2nd when I've driven those!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#5 | |
Thanks guys.
True , drove my 59 Apache yesterday , never saw first gear
Granny gear is good when you're bailing hay all by yourself though!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#8 | ||
My 1979 GMC K25 has an SM465 in it behind a 350 SBC. In 4-low and granny 1st, it was like a billy goat.
But for normal driving... I never used low gear. The shifter even showed L-1-2-3-R. So even though it was a "4 speed" it was normally used as a 3-speed. ![]() Gary
Later after these trucks GM started marking the shift knobs with L, 1, 2, and 3 to make them idiot-proof.
You mean you can get out and walk beside the truck while it drives and you load hay?
So what would be a good 4, 5, or 6 speed to put behind my zz4 350?
Tko 600
#13 | |
Who Changed This?
![]() Join Date: Jan 2013
![]() You could walk along side the truck when it was in low/low. I think it had 4.56 gears, too.
Yes. But loading is to risky for me. Setting the hay out (square bales) is a different story. Just let it idle in low across the field while you sit in the back and chunk the hay out. And if for some reason a cow is being stupider than normal and gets in front of the truck, you are going so slow the truck will just gently push them out of the way. But trees and fences, well, they don't move so easy!
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
#15 |
Good performance 4spds came in cars, such as Muncie M20/M21/M22, Borg Warner Super T10, and Saginaw (if you're not real hard on it). NV3500s are a good 5spds requiring hydraulic clutch as well. I'm not into 6spds. Too much unnecessary rowing for my liking. 4spd is all you need, unless you want O/D, and that's where 5spds come in
#16 |
NV3500 is rated for 300 foot pounds or less , you will break it , t 10s are common and reasonably priced , I had one of those behind a stout 350 [with dart sportsman heads] for years and it received alot of abuse and held up well , broke alot of other stuff though
#17 | |
-klb
#18 | |
#19 |
![]() Join Date: Dec 2012
Did the same thing in my '66 and always regretted it.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#20 |
LOL. My old 250 six with the granny low trans and a 4.11 rear was so low geared that to get it going on ice or hard packed snow, I put it in first, let out the clutch, got out of the truck and pushed against the door. As soon as the truck started to move, I hopped in and went on my way.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
#21 |
Can you give info as to why your regret going from Auto to Manual?
Just curious. Thanks for all the input guys I've been keeping my eye open on Kijiji to see if something reasonably close and cost effective shows up.
#22 |
That truck was a bit of a daily driver, and it was a real pain in the rear in stop and go freeway traffic...
#23 |
Active Member
![]() Join Date: Nov 2002
My 71 Longhorn has a Saginaw three speed overdrive with column shift. Good performance and mileage. I installed this when I built the truck about five years ago. It's not a hot rod but fun to drive. Daily driver during the summer.
Don Brace 55 Nomad 56 Nomad 58 Impalla Coupe 58 Bel-Aire 4D HT 61 Impala CVRT 409 4 SP 2- 71 Longhorns Always looking for old toy trains, Juke boxes Pin ball and game machines. |
