Old 04-27-2017, 12:56 PM   #1
71PICKEMUP
71PICKEMUP's Avatar
throttle linkage
What is an easy method to link between the factory
pedal assembly and an Edelbrock carburetor on a small block?
71PICKEMUP is offline   Reply With Quote
Old 04-27-2017, 02:11 PM   #2
dirish
dirish's Avatar
Re: throttle linkage
If you mean throttle cable, factory part # is 6264974.
I bought a reproduction from classic industris I think.
Fit was perfect, took 5 minutes to install.
dirish is offline   Reply With Quote
Old 04-27-2017, 03:50 PM   #3
71PICKEMUP
71PICKEMUP's Avatar
The '63 uses a linkage rod, not a cable. I'd prefer to keep it simple and not convert to a cable design.
Old 04-27-2017, 04:20 PM   #4
forestb
forestb's Avatar
I used a threaded rod and 2 heim joints
forestb is offline   Reply With Quote
Old 04-27-2017, 04:22 PM   #5
forestb
forestb's Avatar
another thread on the subject
http://67-72chevytrucks.com/vboard/s...rottle+linkage
Old 04-27-2017, 05:23 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
That's what I did on my 66.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-27-2017, 10:37 PM   #7
vin63
It's Better With Nitro
vin63's Avatar
I've used different varieties of threaded swedged throttle tubes on customer projects like these from Speedway: http://www.speedwaymotors.com/Search...eaded+throttle
They come in aluminum and steel versions in a multitude of different lengths. Hardware is pretty standard for either quick release or rod end type connectors. I actually recently used an aluminum threaded throttle tube version on my 63 Tempest project since the original throttle link was damaged beyond repair.- I was able to use the original carb quick release connector and used a rod end to replace the one that was integrated with the OE rod.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-27-2017, 11:10 PM   #8
63longfleet
I took mine off a quadrajet off of a mercruiser boat motor, already set up for a rod attachment
63longfleet is offline   Reply With Quote
Old 04-27-2017, 11:32 PM   #9
Captainfab
60-66 Nut
If you have installed your small block in the original V8 location, you can also use an original V8 throttle linkage.
Old 04-28-2017, 12:26 AM   #10
padresag
depending if he had an I6 in there previous, there is a different length of firewall bellcrank to be used with the sbc
ron
padresag is offline   Reply With Quote
Old 04-28-2017, 09:01 AM   #11
LT1 Burb
LT1 Burb's Avatar
I have some factory linkage if you need it.
LT1 Burb is offline   Reply With Quote
Old 04-28-2017, 02:43 PM   #12
71PICKEMUP
71PICKEMUP's Avatar
PM'd you.
Thanks! Danny
