#26 | |
Re: Need detailed pics of front brake line routing
#27 |
I know this is an old thread, but how close will this be to a 1971 C10? The reason I ask is that I have a 1960 Suburban and bought the stainless steel brake line kit from CPP and I'm having a heck of a time figuring out how to run them.
They sent me some pics, but I think it was a '71 as the lines run outside the frame rails, it appears. On my '60 they have to run on the inside and they confirmed that. I finally figured out which vertical line is the front and which is the rear. Part of my issue is I don't yet have the master/booster/proportioning valve assembly as I've been trying to wait until some already purchased parts are installed. I hate sitting on parts. I've also ordered the bracket from CaptainFab and thus not sure if the CPP master/booster is the way to go or just go with the ones known to fit with the Captain's bracket. I think part of the confusion is that they don't appear to use the factory mount points, so everything seems to be loose. Hopefully I can also find a good way to secure these to the frame and/or crossbar. |
#28 |
![]() Join Date: Feb 2016
The 67-72 lines are secured with clips that attach to the frame through holes drilled in frame without a separate fastener. You might look in the 60-66 C10 section for better info. As far as I know there are no differences in the long beds and the Suburbans. The 67-72 lines are run on the inside of the frame. Someone will correct me if I'm wrong but I don't believe anyone is making an exact repop of the original clips. (Photo show some originals, the two heavier looking ones in the center are the fuel/ brake line clips) The fuel line goes in the upper part of the clip and the brake line in the lower. On the rear of the front cross member the clips are different as the lower part is smaller for 3/16" line. Someone parting out a long wheel base truck should be able to save some clips for you, or go to the U-pull-it and look for a donor vehicle with the correct size tubing, or you can use any number of aftermarket clips or loop straps.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#29 |
An old thread, but a life-saver! This thread and a few others have been instrumental in helping me install my Inline Tube SS lines today.
It makes more sense once a few of the lines are on, but would it have been too much to ask for Inline to label the lines for those of us who had a complete teardown with no pictures from 'before'?? Having now done this I'm sure a second time would be much easier to figure out, but some of the bending had me thrown for a loop until I saw the pictures on here. Thus far the new lines have gone on with only gentle nudging and bending in a few spots. I am only working on the rolling chassis right now so the lines to the master cylinder won't be hooked up till the cab is on so I won't be able to comment on the complete set-up till then. I've read the good-and-bad comments about Inline so I will definitely offer my opinion once it's all done. So far I have no complaints other than lack of labeling for the newbies like me! |
#30 |
One of the First
![]() Join Date: Jan 2000
Exactly what I was looking for, love this site!
#31 |
Active Member
![]() Join Date: Oct 2016
My lines don't line up with the tab on the rear diff. It looks like it needs the bolt in tab using the diff cover bolt. Input please guys
1972 factory 2wd blazer. 12 bolt rear, confirmed it is the correct rear end. |
#32 |
Factory 1/2 ton 5 lug rears with coils should have this hose (Photo 1) and the lines should go here, (Photo 2) and the fittings should be 1/4" not 3/16". Lines that go to the tab on the cover are early 6 lug lines with 3/16" fittings.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 04-28-2017 at 04:59 PM. |
