Old 04-29-2017, 07:44 PM   #26
ChuckLee
Re: My 67 build
Good job sirs. Like it! Keep up the good work. What you doing for brake master/booster?
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 04-29-2017, 11:09 PM   #27
SouthGA 67
Re: My 67 build
Thanks ya sir. We are using the booster out of the 2014 corvette that got totaled "26,000 miles" We are using the engine, trans, booster,wiring harness "modified of course" radiator "also modified" . We used headman medium headers on it and had to slightly cut the frame. The plans are to use a stage 2 cam from vengence racing out of Atlanta. The ecm has already had the redline and security thing removed. We plan on sending the ecm the vengence to tune it when we do the cam. Thanks for the replies guys.
SouthGA 67 is offline   Reply With Quote
Old 04-29-2017, 11:16 PM   #28
SouthGA 67
Re: My 67 build
This is the color I decided to go with which is blade silver. Thinking about doing a gunmetal satin wrap on the raised part of the hood. If it's not what I'm looking for we will remove it. We will be good no with the TMI for interior which will be black with red stitching.
Old 04-29-2017, 11:21 PM   #29
SouthGA 67
Re: My 67 build
Heres the interior.
Old 04-30-2017, 09:12 AM   #30
Smittee
Re: My 67 build
Originally Posted by twotrucks View Post
Are your upper control arms on backwards (swapped side to side)?
Truck is looking good, wish I was ready for paint.
Yeah, I think Twotrucks is correct-they are backwards. At least according to the way mine had been when I got it and I am pretty sure the guy before me really knew what he was doing. The frame shop that aligned my truck never corrected me either, so I figure this picture illustrates how it should look. Notice the front is longer than the back "leg". That is how the new TCI control arm on my kit are also. It has to do with the caster effect I believe.
Note: I am NOT trying to be critical with this post. I just think that your ride and wheels might suffer if this is not corrected. So, hopefully this and Twotrucks comment will make it a better ride for you!
Smittee is offline   Reply With Quote
Old 04-30-2017, 10:06 AM   #31
SouthGA 67
Re: My 67 build
Wow great eye guys. I see what your saying now and yes they are in the wrong side. Thanks again.
Old 04-30-2017, 03:39 PM   #32
SouthGA 67
Re: My 67 build
Sanded, taped and ready to roll. Just rolled her in the booth.
Old 04-30-2017, 05:21 PM   #33
SouthGA 67
Re: My 67 build
Looking good so far. Bout to put some clear on it.
Old 04-30-2017, 06:03 PM   #34
SouthGA 67
Re: My 67 build
Clear is looking good
Old 04-30-2017, 06:20 PM   #35
SouthGA 67
Re: My 67 build
Turned out great.
Old 04-30-2017, 06:22 PM   #36
SouthGA 67
Re: My 67 build
Just a few more pics.
Old 04-30-2017, 06:32 PM   #37
mooseknuckles
mooseknuckles's Avatar
Re: My 67 build
Nice! I like those TMI seats..
mooseknuckles is offline   Reply With Quote
Old 05-01-2017, 08:43 AM   #38
SouthGA 67
Re: My 67 build
Few untaped.
Old 05-01-2017, 09:33 AM   #39
flashed
Re: My 67 build
Looks great .
flashed is offline   Reply With Quote
Old 05-01-2017, 11:05 AM   #40
SouthGA 67
Re: My 67 build
removed the tarnish and crud off of the vin tag and it turned out like new.
Old 05-01-2017, 12:18 PM   #41
Smittee
Re: My 67 build
That paint looks GREAT! Attention to detail on that VIN plate as well. Can't wait to see the finished truck.
Old 05-03-2017, 04:01 PM   #42
SouthGA 67
Re: My 67 build
Time to put a little time in. Hope to have a rolling by chassis by tonight. Brakes, rear end, axles, and tires/wheels on the truck.
Old 05-03-2017, 04:46 PM   #43
69short
69short's Avatar
Re: My 67 build
The paint looks nice. Good luck getting it rolling
69short is offline   Reply With Quote
Old 05-03-2017, 07:34 PM   #44
SouthGA 67
Re: My 67 build
Going good so far.
Old 05-03-2017, 07:37 PM   #45
SouthGA 67
Re: My 67 build
Also we don't have the correct lug nuts yet but they will be here Friday.
Old 05-04-2017, 09:02 AM   #46
SouthGA 67
Re: My 67 build
I'm going to post this in the classifieds but for you guys following my build know that these early classic drop spindles wouldn't work with my wilwood brakes. I never mounted them so they are brand spankin new. They are 2.5" drop. Let me know if your interested. Thanks JT
Old 05-04-2017, 03:12 PM   #47
SouthGA 67
Re: My 67 build
Rear end is done along with the rear brakes. We plan on putting the cab on this afternoon and taking the bed off to get ready for the paint booth.
Old 05-04-2017, 03:30 PM   #48
SouthGA 67
Re: My 67 build
Bed is off.
Old 05-04-2017, 04:31 PM   #49
boynton
boynton's Avatar
Re: My 67 build
Interested in seeing how the dash turns out. I've never been able to get away from the classic look but I really enjoy seeing different approaches.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 05-04-2017, 05:00 PM   #50
SouthGA 67
Re: My 67 build
Quick question. Are these helper springs in the rear worth keeping? I'm not going to have anything in the bed or towing anything. One of them is hitting harder on the frame and it has the rear of the truck slightly cocked to one side. Thanks JT
