Old 12-21-2016, 10:31 AM   #101
regan wilson
regan wilson's Avatar
Re: Mr Green Jeans - the 69 (or not) chevy, er gmc, project
Originally Posted by OKGMC4 View Post
Welded up a frame from square tubing. Cut and router some wood. One coat of conditioner, two coats of stain, and 3 coats of urethane clear. There's some dust in the clear that I wanted to sand and buff but ran out of time. He plans to have it in the Starbird show in a couple days.
I really like that bed cover. Could you build a multi piece one that would be easily removeable and work around roll cage struts?
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 12-21-2016, 11:41 AM   #102
SuperBuickGuy
really cool build.
SuperBuickGuy is offline   Reply With Quote
Old 12-22-2016, 07:36 AM   #103
OKGMC4
OKGMC4's Avatar
I bet with enough time it could be done. Making it multi piece would be the easy part, EASILY REMOVABLE would be the trick. Steel and wood could make for some weight. The one I did on the 56 that is on a hinge is a little heavy to lift up when it's time to fill the gas tank. That's why the one I did on the 59 is solid mounted and the fuel fill goes through the floor.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 01-17-2017, 12:55 PM   #104
OKGMC4
OKGMC4's Avatar
Since I chopped the roof the glass is now too tall and also too narrow, since I plan on flush mounting the glass. So I'm building the window frame to fit a stock windshield. Ill also reskin the pillars since they have an indent for the now deleted rubber seal.
Old 01-17-2017, 12:57 PM   #105
OKGMC4
OKGMC4's Avatar
More done outside. I'll still need to rework the inside to hide the lip that holds the glass.
Old 01-23-2017, 07:32 AM   #106
OKGMC4
OKGMC4's Avatar
I got the pillar covers made and welded in. Still have to put in a cover for the lip on top and need to start mounting the dash.
Old 01-23-2017, 07:39 AM   #107
OKGMC4
OKGMC4's Avatar
Something I'm thinking about...I want this truck to be as modern as can be. That's why I want the LS engine, disc brakes, flush mounted glass, etc. when was the last time you saw a new car with sealed beam headlights? Considering a set of projector headlights from Dapper Lighting. Any thoughts?
Old 01-23-2017, 07:57 AM   #108
GR8-68
GR8-68's Avatar
This is a awesome build, following along for this one. Nice work
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 01-23-2017, 11:13 AM   #109
knomadd
knomadd's Avatar
I bought a set for mine. Haven't installed them yet as I'm in the process of an LS swap myself. Looks like a good product though.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-23-2017, 11:22 AM   #110
JustToxic
JustToxic's Avatar
Some beautiful fab work going on here. I'm going to start following from here.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 04-30-2017, 08:23 AM   #111
OKGMC4
OKGMC4's Avatar
I'm getting the distinct feeling that I will end up doing everything on this truck twice. Because I upgraded from a 5.3 to a 6.0 and also because of the Dakota rack I installed, I was having trouble routing the steering shaft from the inside of the frame and could also use a slightly bigger header and exhaust. Doug Thorley headers fit nice but hang way over the frame rail. I bought a set of Doug's headers part # D314 that tuck tighter, have a larger primary, and will upgrade me from 2.5" pipe to 3".
Old 04-30-2017, 08:29 AM   #112
OKGMC4
OKGMC4's Avatar
The bad news...they are for 73-87 trucks. With 67-72 V8 mounts in the front holes I needed to move the engine back as the #1 primary hits the bracket. After the fact I realized that I may have been able to use slider plates on the block rather than the solid adapter plates I had BUT I reasoned that if they fit 73-87 I can switch to 73-87 motor mounts and slider plates and it should fit. I was correct in that assumption. Before...
Old 04-30-2017, 08:31 AM   #113
OKGMC4
OKGMC4's Avatar
After...
Old 04-30-2017, 08:36 AM   #114
OKGMC4
OKGMC4's Avatar
Moving the engine back changes how the engine covers fit at the firewall.
Old 04-30-2017, 10:36 AM   #115
riddinlow99
great looking build looking forward to what else you will do to it.
my 70 build thread
http://67-72chevytrucks.com/vboard/s...=697112&page=2
riddinlow99 is offline   Reply With Quote
Old 04-30-2017, 08:24 PM   #116
webberjames95
wild
webberjames95 is offline   Reply With Quote
Old 05-25-2017, 08:58 AM   #117
OKGMC4
OKGMC4's Avatar
also had to install a high hump. I guess installing the 73-87 motor mounts may have raised the front of the engine, or I just plain screwed up and had the trans at the wrong angle. Either way I had to raise the trans to get back to 3 degrees and it hit the floor. Seems OK now and I've started building the exhaust and planning the new trans cross member.
Old 05-25-2017, 10:12 AM   #118
OKGMC4
OKGMC4's Avatar
Rebuilding exhaust. This time with an H instead of an X.
Old 06-07-2017, 05:39 PM   #119
OKGMC4
OKGMC4's Avatar
Cut and modified crossmember to fit exhaust.
Old 06-11-2017, 01:08 PM   #120
NewType72
NewType72's Avatar
Damn, big time bummer with having to sand down the degree on your covers, but they sure do look great at least! Those headers fit awesome too!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 06-15-2017, 08:06 PM   #121
OKGMC4
OKGMC4's Avatar
I got the shaft today. The driveshaft. Wh..what were you thinking? You've a bit of a potty brain haven't you? As it turns out I also had to install a POL drop crossmember because I have 6" drop springs and the driveshaft was going to hit. I can only get 6 of 8 bolts in but will drill "clearance" them when the body gets raised.
Old 06-16-2017, 12:27 PM   #122
knomadd
knomadd's Avatar
I had the same issue with my POL crossmember. Haven't opened them up yet though. What diameter driveshaft are you running?
-Duane
Old 06-16-2017, 02:03 PM   #123
OKGMC4
OKGMC4's Avatar
I didn't verify but the driveshaft shop guy said 3.5". He asked how much power I was going to make because he thought the 1350 joints were overkill. I told him 475 to 500 crank hp and he said this should be good. My 56 GMC with a stock 5.3L is running a much smaller shaft, but I just had a 70 chevelle shaft (that I already had) cut down to fit.
Old 06-18-2017, 01:38 PM   #124
knomadd
knomadd's Avatar
Thanks. I think I'm going to end up with the same size driveshaft. Was hoping to run a 4" aluminum shaft, but I don't think it's going to fit.
-Duane
Old 06-26-2017, 06:28 PM   #125
OKGMC4
OKGMC4's Avatar
More exhaust progress. Hope those custom Spintech mufflers sound as good as they look. In retrospect I should have done the exhaust through the frame in a 45 instead of 90 degree bends. Not going to change it now though.
