Old 04-30-2017, 11:01 PM   #1
Portland68
Best bang for my buck - Drop Spindles
Hello everyone, I'm planning on lowering my 68 SWB here pretty soon and converting it over to 5 lug and was hoping for your input. I have been talking to Charley from Charley's Drop Shop in Portland, OR about doing the work and am deciding between drop spindles vs. drop A arms and wanted to get some opinions on what is the best option and which drop spindles you recommend. I am willing to spend the money for the right set, links would be appreciated!
Portland68 is offline   Reply With Quote
Old 04-30-2017, 11:13 PM   #2
OARNGESI
OARNGESI's Avatar
Re: Best bang for my buck - Drop Spindles
Forget drop a arms go with spindles ECE or CPP sell quality products some say cpp has bad customer service though I mad several orders through them and never had a issue
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 05-01-2017, 10:33 AM   #3
weq92f
weq92f's Avatar
I'm running ECE 2.5" drop spindles and 2" drop springs on a 67 w/disc brakes. 255/40/20 rubber up front, no issues at all. Quality parts and nice drop.
Those components can be had for about 400 bucks ( minus the wheel/tire ).
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 05-01-2017, 10:35 AM   #4
weq92f
weq92f's Avatar
Oh, x2 on not going with drop arms. The ones I've seen on the road and at shows have a bowl or cup for the bottom of your coil spring that ends up being the lowest part of your truck ( hanging down dangerously below the lower A-arm ).
Some look/function better than others I'm sure so YMMV.
-klb
Old 05-01-2017, 05:56 PM   #5
Kennuck
Kennuck's Avatar
I used Western Chassis 2.5 drop spindles that accept the 73-87 discs. $249 on their site.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 05-01-2017, 09:38 PM   #6
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
I recommend keeping your stock control arms and going with an entire kit from CPP or somebody else. I went with CPP and it went well. I put front disc brakes on lowered spindle and leaf springs...power brakes and power steering. Good to go! My only real expense besides parts was paying a shop to put new ball joint and shaft in control arms and he charged me about $250 and then $110 at Les Scwab for alignment. If you have shop or big enough garage you can do yourself. I can help if you need some.
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 05-02-2017, 11:08 AM   #7
JohnJ@RideTech
JohnJ@RideTech's Avatar
Ive got a set of drop spindles that are pretty nice and give you about 2.5in of drop.
They are cast pieces and use a CNC'd chrom-moly 4140 pin.
Check out the link below and let me know what you think.
http://www.ridetech.com/store/1963-1...k-spindle.html
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 05-02-2017, 11:22 AM   #8
demian5
demian5's Avatar
Too much coin for bolt on caliper adapters.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-02-2017, 11:33 AM   #9
Oregon 1967 GMC
That looks like a good deal to me and after reading the testimonials it looks promising. I will probably go that way on my '65 Chevelle once I'm done with the truck. Thanks for sharing JohnJ.
Hey man
