04-30-2017, 05:50 PM | #1 |
?Jet performance carburetors
Anyone here have any expirience with their stage 2 quadrajets? They are sulposed to have all the modifications to correct the common quadrajet issues. I have one from National carburetors but not happy with the way it is running, bogs down and I have a hard time starting when hot or when it has sat for more than a couple days, also seems to flood wgen hot. It worked perfect the first couple weeks I had it. It is either this or an edelbrock.
04-30-2017, 05:56 PM | #2 |
Re: ?Jet performance carburetors
I don't have experience with JET I do have experience with Quadrajet Power out of Texas. They will build you a carb exactly for your application for about $250 if you send them a core. I have one on my wife's 455 Firebird works great.
05-01-2017, 01:00 AM | #3 |
K5drive
Do you have a spacer under it ? Or a hear shield
05-01-2017, 02:21 AM | #4 |
No spacer, just sits on a stock manifold.
05-01-2017, 03:27 AM | #5 |
No spacer but it does have a nice thick heat shield or gasket that it came with. Im pretty sure its flooding because I can smell the fuel. National carbs has good prices but, they just reman their carbs. No mods to improve the more common issues.
05-01-2017, 07:04 AM | #6 |
I used one on a 454 in a 70 chevelle years ago. Was set up perfect from the factory and didn't even make an adjustment and it ran perfectly for 2 years with no problems before I sold the car. I got mine from summit.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
