brake drums
Does anyone make a brake drum that can hold the factory spring? I am about to redo my front brakes and have a feeling the drums may need to be replaced. They are still riveted to the hubs. Thanks,
Bill |
Re: brake drums
Anti-vibration spring around outside of drum you mean? Unnecessary so not included any more.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
![]() Join Date: Apr 2016
Re: brake drums
What changed in the engineering of the drums to make the anti-vibration spring unnecessary? I would be kind of disappointed to put new drums on and end up with howling brakes.
Re: brake drums
I am curious about this as well. I read several admittedly old threads about how important the Anti-vibration springs were. I will say that the new NAPA drums I installed on the rear are thicker and heaver than the stock ones they replaced. I purchased them prior to reading up so I figured I could just change them out later if it was a problem. If in fact it makes a difference I would rather just get the correct ones for the fronts. I probably won't tear into them for at least a few weeks so I have time to order something if I need to.
#5 | |
They can be better described as harmonic dampeners. Drums and rotors on the lathe have to be wrapped with thick rubber straps for the same reason. Will sing like a bell if turned while naked. Here are the drums I got from NAPA for my '69 c10. Nearly identical to the original units. Guess one could try transferring the springs over if so inclined.
