Old 05-02-2017, 06:04 AM   #1
Kent Bingham
Buy hookers or a lift kit?
My truck is a 1980 GMC Sierra Classic, small block, 4 wheel drive, short box. Previous owner put some headers on. Turns out the front driveshaft is beating the everloving snot out of the one header tube on braking. Front end sags obviously. I hear that Hooker headers have more clearance than the current Hedman headers, so I could replace them. They are new though. My other option is to put a lift on it. I've done a few jeeps but no GM's. I figure the 37 year old springs could use swapping out. The only reasonable lifts that I find, under 6", use lift blocks in the rear. I'd like new rear springs. Anyone know if I can get a 2"-4" lift that has new rear springs? Or possibly taller springs from something else that I can match the front lift to? Should I buy new rear leafs from LMC or someone and then use the blocks? Let's have your thoughts.
Kent Bingham is offline   Reply With Quote
Old 05-02-2017, 06:20 AM   #2
andrewmp6
Re: Buy hookers or a lift kit?
For the lift look at http://offroaddesign.com/
Old 05-02-2017, 11:17 AM   #3
Jeepwm69
Not the kind of hookers I was picturing......
I would get the lift.
If you buy different headers, you still have sagging springs.
If you put a lift on there, your sag is fixed and your existing headers will work fine.
Jeepwm69 is offline   Reply With Quote
Old 05-02-2017, 11:34 AM   #4
Kent Bingham
That's what I was thinking. I'll have to undent the current headers, but that's it. Unfortunately, the cost is a wee bit higher.
Old 05-02-2017, 11:37 AM   #5
Kent Bingham
Thanks for the link. It seems Tuff Country makes rear lift leaves. It's been a long time since I rode in anything with a Tuff Country lift in in. Do they still ride like a haywagon?
Old 05-02-2017, 12:13 PM   #6
daddyjeep
daddyjeep's Avatar
I was thinking adding a leaf, but since your springs are so old it just makes more sense to replace them. I have read where a lot of guys are happy with ORD as mentioned above.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-02-2017, 07:47 PM   #7
81k
81k's Avatar
If your leaf springs are sagging, even swapping in new stock height springs will net you a suspension lift over where your truck sits currently. Whether that would provide you with ample clearance for your header I'm not sure.
Allied Spring has a few shops around your area in East Syracuse, Rochester, and Elmira. They should certainly be able to help you obtain stock height spring replacements.
81 GMC K2500/C6P
Last edited by 81k; 05-02-2017 at 08:11 PM. Reason: Typos will be the emd of us all.
81k is offline   Reply With Quote
Old 05-02-2017, 10:18 PM   #8
Pine Bark Auto
Since you say it only happens under braking, I would try a 2" add-a-leaf to the front and see how you like it. Usually just levels out the truck and doesn't look odd with stock or near stock size tires. Chip.
Pine Bark Auto is offline   Reply With Quote
Old 05-03-2017, 03:08 AM   #9
andrewmp6
Off road design also has their own custom leafs,I would email them or talk to them on the phone.They do run what they sell and build some amazing trucks.
Old 05-03-2017, 05:29 AM   #10
Kent Bingham
The truck looks level. I just assume they are tired because they are so old. They've been holding that truck up for a long time. Maybe sagging was the wrong word to use. I would change that to something that means 'gets lower due to weight transfer'
