Old 06-07-2010, 12:19 PM   #26
68longhorn
68longhorn's Avatar
Re: Oil Leak on New crate motor
I also have 2 leaks on my 330hp crate motor. One in the front, one in the rear. Why so many crate motors that leak? I need to diag mine still
68longhorn is offline   Reply With Quote
Old 06-07-2010, 05:04 PM   #27
71tahoe
71tahoe's Avatar
Originally Posted by 68longhorn View Post
i also have 2 leaks on my 330hp crate motor. One in the front, one in the rear. why so many crate motors that leak? i need to diag mine still
hecho en mexico!
71tahoe is offline   Reply With Quote
Old 06-07-2010, 07:41 PM   #28
68longhorn
68longhorn's Avatar
Haha true. My 86 305 has less leaks @ 130k miles than my crate motor does at 10k miles.
Old 09-06-2010, 11:42 PM   #29
'71 Surf Wagon
Originally Posted by akpackfan View Post
I just had the same problem with the truck I just bought with a 350 crate motor in it and it ended up being the hole just above the starter solenoid that was intended to be used for a dipstick tube didn't have anything in it. No tube or plug so it was open to the oil pan and any time the engine was running oil would splash out in fine dropplets. I had to look between the header tubes, just to the rear and above the starter solenoid to see it. Might want to check it out. Symptoms were oil burning off the header tubes and a good puddle of oil on the ground, running off the bottom of the starter.
What did you plug it with? I swung by O'reilly and Auto Zone today, neither had a solution to plug that hole. Part number anyone?
'71 Surf Wagon is offline   Reply With Quote
Old 09-07-2010, 01:29 AM   #30
El Jay
Gone to greener pastures
Well (& I'm not being a smart azz here), if worse comes to worse, install another dipstick tube & dipstick.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 08-12-2013, 08:39 PM   #31
LorcinLS1
This might be an old post, but is the exact problem I have. I found the port just a few minutes ago and it has no plug. Unfortunately I took over someone else's project and wasn't given the motor install instruction sheet from GM. The unplugged port was spraying random droplets right onto the inside of the header and dripping onto the starter giving the impression it was the pass side valve cover. Thanks Akpackfan this post saved me a ton of ongoing aggravation.
LorcinLS1 is offline   Reply With Quote
Old 08-12-2013, 08:59 PM   #32
My son gave me this
My son gave me this's Avatar
Originally Posted by Racinaround View Post
If its a real GM Create Engine then it should be under warrenty????
You shouldn't have to mess with it
And spoil all the fun?
My son gave me this is offline   Reply With Quote
Old 08-12-2013, 10:54 PM   #33
Wrenchbender Ret
The Goodwrench engines come with new valve covers & new oil pan. The plug for the extra dipstick hole is provided with the engine.
I have put hundreds of these engines in & any oil leaks have been installer faults.
Wrenchbender Ret is offline   Reply With Quote
Old 10-18-2013, 07:08 PM   #34
Banderian
Banderian's Avatar
Smile Re: Oil Leak on New crate motor
Yep. Even though I had never done it before, I installed my crate 350 without much problem. Fortunately, I looked at the passenger side dip stick hole and realized something was missing. I looked in the bag that the warranty was in, and there was the plug I needed. Tapped it in and haven't had any problem there. Of course, I have other leaks, which is why I'm reading this thread.
Banderian is offline   Reply With Quote
Old 10-19-2013, 08:12 AM   #35
bigmac73
bigmac73's Avatar
no telling how long these engines sit in a warehouse, and gaskets and seals dry out over time
i had the same problem with a old 2 barrel carb i got from a parts house one time, bolted it on and the gaskets where dried out from sitting on the shelf for so long that the thing leaked like a sieve when i fired it up, had to take it apart and replace the gaskets
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 05-01-2017, 10:14 PM   #36
wlt3355
Not sure how old this thread is, but still giving solid advice.
I too have a new 350 crate motor that has that same mysterious oil leak around the starter, and after checking everything I could think of, I finally noticed a tiny bit of oil on the recently washed off area, and lo and behold...there is that hole in the block for (I assume) a right or left hand dipstick, and as mentioned before, it just splashes enough to keep everything lubricated well...NOW HOW DO I GET TO THAT SPOT AND WHAT WILL FIT IN THAT HOLE?
wlt3355 is offline   Reply With Quote
Old 05-02-2017, 01:58 AM   #37
El Dorado Jim
I just installed a crate engine in my truck, I used the dipstick tube and dipstick in the drivers side hole and they sent a solid steel plug to install in the hole that you dont use...I didnt like the plug, because it would slip on down into the engine,there was no way to keep it from doing that,so I took a 3/8" bolt and cut the threads off.it was a long enough bolt to have about 3/4" of smooth bolt left and the head....I used gasgacinch gasket sealer and glued it in the hole, no way for it to ever fall into the engine and it is sealed good,you could use pretty much any gasket sealer or a silicone gasket sealer...
El Dorado Jim is offline   Reply With Quote
Old 05-02-2017, 08:58 AM   #38
wlt3355
I am actually thinking of just getting another dipstick, that hole is deep behind headers, starter and not easily accessible, I just do not see to reach it without removing the starter
I feel bad, been chasing this leak for about the 600 mile life of this engine and just now discovering this
