Closed Thread
Old 04-29-2017, 03:13 PM   #5251
paul blair
Re: What did you do to your truck today? Chapter II
Nice! Sea ten
paul blair is offline
Old 04-29-2017, 04:56 PM   #5252
Metaldoc
Metaldoc's Avatar
Working on a spare tire mount that tucks it in the front right corner of the box
Metaldoc is offline
Old 04-29-2017, 05:07 PM   #5253
rmr_69c10
Started the removal of the old cracked sealer and clean up of the drip rail so it can be resealed soon. Also this week, installed a new fan shroud to keep it cool for the summer and got it tuned pretty well now. Of course, I discovered the previous owner had the center link installed backwards, but one thing at time... Lots of things to do, but at least progress is being made.
rmr_69c10 is offline
Old 04-29-2017, 05:56 PM   #5254
OregonNed
OregonNed's Avatar
Cleaning up gauge wiring today and a new temp sender
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 04-29-2017, 08:26 PM   #5255
46stude
Swapped out the faux wood Grant GT wheel for an actual old school Superior "the 500" wheel:
46stude is offline
Old 04-30-2017, 10:55 AM   #5256
ghalperin
ghalperin's Avatar
I had a busy day yesterday. All by myself.
Pressure washed and sold the engine.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Old 04-30-2017, 11:37 AM   #5257
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Hey Glenn, if you don't mind me asking, how much did you get for the straight six motor? I have one in good running condition that I'm trying to sell. Thanks.
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline
Old 04-30-2017, 12:12 PM   #5258
ghalperin
ghalperin's Avatar
For the 250, I asked $500 and got $350 within a few hours. I kept the flywheel, clutch and alternator. I may have left some money on the table, but I just wanted it to go away quickly. The buyer offered $300 and I countered with $350. I would have taken less.
Glenn
Old 04-30-2017, 09:51 PM   #5259
69canam
69canam's Avatar
Finally got her out of the weather. Gutted and rebuilt the one car garage. My wife and I started this project over a year ago. But we took some time off to gut and remodel our master bathroom, so this one got delayed. Now safe and secure and dry. Just in time for the rainy season here in Florida.
69canam is offline
Old 04-30-2017, 10:05 PM   #5260
Oregon 1967 GMC
thanks bro!
Hey man
Old 04-30-2017, 11:29 PM   #5261
mud.man.rj
mud.man.rj's Avatar
Nice job on the truck shelter.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 04-30-2017, 11:30 PM   #5262
ghalperin
ghalperin's Avatar
I found these lying under the truck.
It took an hour and a half for them to fall out.
3 cross members, 2 rear shock mounts, 2 rear bump stops, 2 ball joints and 1 Z-bar mount.
A good air hammer, high pressure from the compressor and a new bit made it fairly easy. Thank you Snap On.
Glenn
Old 05-01-2017, 01:59 AM   #5263
Dave K.
Dave K.'s Avatar
Finally got my rally's swapped out with the new Cucv blazer rims. Got a lot of input from everyone here before choosing route to go. Hubcaps look great on them as well. Thanks all.
Dave K. is offline
Old 05-01-2017, 08:41 PM   #5264
custom10nut
custom10nut's Avatar
I finally took the time to get up under the dash to fix some things.
I hooked up ground wires to the tach an dash panel, and hooked up the wire for my tilt column shift indicator light.
Everything works!
It's been a good day
custom10nut is online now
Old 05-02-2017, 07:17 PM   #5265
iriereggaeman
iriereggaeman's Avatar
Indeed, just in time! Nice plate. (Go Gators!)
iriereggaeman is offline
Old 05-02-2017, 07:33 PM   #5266
74baggedbug
Took it out for a spin, enjoyed the nice day and cleared my head
74baggedbug is offline
Old 05-02-2017, 07:53 PM   #5267
Nomadicflyer
Nomadicflyer's Avatar
Tried to fix my driver door windows. Welded the pivot post back onto the wing window frame, riveted new seals in, welded the kept nut on the rear window track guide, installed new rollers, and now the window won't roll up past 1/2 way
Maybe tomorrow will be profitable. Today was a loss. Mounted/gapped the hood yesterday, so the week has been 50/50, so far.
1972 C20 Fleetside "Miss Olive"
http://67-72chevytrucks.com/vboard/s...d.php?t=721563
Nomadicflyer is offline
Old 05-02-2017, 08:25 PM   #5268
midniteblues
midniteblues's Avatar
Awoke this unfinished project and took it for a putt putt through town.
Now that my 4x4 is mobile I need to get back on this.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 05-02-2017, 09:22 PM   #5269
custom10nut
Today, I finished the New Flxplte and Starter Project. When I hit the key
It sounded better than it ever has. It sounds like a new truck. I also put the Power Plate in my carburetor, and man what a difference! now I have to figure out why my ach is reading low still. But that's another project.
Old 05-04-2017, 01:22 PM   #5270
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Yesterday I installed the dual snorkel Air Cleaner I got from Rock Auto. I had to to do a couple tweaks like remove the Oil Fill Tube and plug carb hole where hose from heat thing went.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 05-04-2017, 03:04 PM   #5271
Oregon 1967 GMC
I like that, looks clean. Could you give me the part number or more info? Thanks.
Hey man
Old 05-04-2017, 03:21 PM   #5272
Big Block
Big Block
Big Block's Avatar
Love the dual snorkel air cleaner. Nice upgrade.
Big Block is offline
Old 05-05-2017, 06:02 PM   #5273
Stocker
20' Daredevil (Ret)
Stocker's Avatar
x3 on the dual snorkel air cleaner, very nice!!
Got my new drag link and tie rod ends installed, and I'll have the alignment checked next week. Nice to have the 45-year-old steering parts finally replaced.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline
Old 05-05-2017, 09:57 PM   #5274
Already Gone
Yes for sure. Its listed under a 1972 Camaro with a350 4bbl engine as an Air Intake Kit and the Goodmark part # is GMK4021230704SX. You can also get them with achrome lid but I want my truck to look kinda stock under the hood. Was about 175.00 US
Old 05-06-2017, 11:50 AM   #5275
ChaseBBC
ChaseBBC's Avatar
blasted and painted the frame today.
ChaseBBC is offline
Closed Thread
