69 C10 Headlight issues
Hi guys
The headlights in my 69 C10 only seem to work sometimes when I turn them on, parking lights always come on. Any suggestions on what it could be? Thanks in advance! |
Re: 69 C10 Headlight issues
1. Dirty Headlight Switch.
2. Bad headlight switch connection (reach up under the dash and move it around and see if lights flicker). 3. Bad Ground somewhere in circuit.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
20' Daredevil (Ret)
![]() Join Date: May 2003
Hi/lo dimmer switch (on the floor near the parking brake) is a common problem. Either the switch or its connector.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#4 | |
Any suggestions on how to get the pins out of the Hi/lo terminal?
After you rebuild that connector, google "headlight relay upgrade" on this site. You will never have to fix that again.
In stock form, the 45 year old wires full of cracks and fuzzy connectors draw too many amps which leads to melted connectors. The relay upgrade turns that wire connector in your hand into part of a relay selector.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
