Old 05-05-2017, 11:08 AM   #1
Nhaydt92
Newbie... is this truck worth it?
Hello everybody I'm a long time lurker but I finally found a truck I may buy. The owner wants 5,400 for it. Says the bodies pretty solid except a smashed front fender. Has the factory interior, stock rear and transmission but converted to floor shift. Has a 350 in it. Has plywood down in the bed, is it possible to remove it and put the factory set-up back in? Just lemme know what you guys think. He says frame is really solid.
Nhaydt92 is offline   Reply With Quote
Old 05-05-2017, 11:12 AM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: Newbie... is this truck worth it?
I'd be going over that whole truck with a magnet to make sure it's not a bondo job.....plus it's just another 350 truck so nothing special at all. I wouldn't give anything more than 3k for it.....just me.
Old 05-05-2017, 11:22 AM   #3
chevylookin
Short Fleet with a small back window standard cab. Very cool. The old bed wood is probably still underneath. You can have a new kit installed with bolts and bed strips if you do it yourself for about $500. Not that hard. I can find a donor fender in my area off CL in a moment's notice or get the repo for about $200 (not recommended unless your good with a drill) Talk him down to $4200 or keep looking. It has been lowered with aftermarket wheels and all so make sure the driveshaft is in line with the diff and tranny or youll burn up u-joints. Take a look under the cab and make sure the frame isnt welded on or rusted along with the cab supports and it would be a great starter project.
chevylookin is offline   Reply With Quote
Old 05-05-2017, 11:28 AM   #4
Nhaydt92
Ok thank you for your replies I will definately do that!
Old 05-05-2017, 11:29 AM   #5
Clyde65
Clyde65's Avatar
Also check the inside and outside around the window.
You really are not going to know if it's worth the $ unless you go look and crawl under, over, in and around. Look at cowl area also, toe boards and cab mounts.
Good luck!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-05-2017, 11:34 AM   #6
PGSigns
PGSigns's Avatar
For what I can see it looks pretty good. Shame he sprayed it black. That may all come off with enamel reducer. Take a really good look at it and drive it. For the east coast and what trucks that are solid are going for here that price is a little high but not a lot if it is in fact as solid as it looks in the picture with the door open. You just don't see many. The west coast guys have it a lot better than us east coast rust belt folks.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-05-2017, 12:21 PM   #7
Nhaydt92
Jimmy
I have noticed this. There definition of rust and ours is a lot different.
Old 05-05-2017, 01:45 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Before I even read any posts, my first thought was $3000 max.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-05-2017, 01:57 PM   #9
Cris
Before you pull the trigger, do yourself a favor and take it to a local garage that can put this on a lift. Check underneath for rust and damage. I'm from California so this looks like a good price PROVIDED there is not a lot of hidden damage and rust. A bent frame or serious rust issues will cost you more than the price of this truck.
Good Luck, Cris
Cris is offline   Reply With Quote
Old 05-05-2017, 03:06 PM   #10
oldusafmsgt
oldusafmsgt's Avatar
If there's little to no rust, it's probably a good deal in New York.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 05-05-2017, 05:09 PM   #11
Nhaydt92
He says the doors and floors are solid. Bedsides I don't see any rust but the underneath does look a little bit more rusty. I'm thinking there's more hidden than what I see but it's hard to find a decent truck around here....
Old 05-05-2017, 05:35 PM   #12
SCOTI
SCOTI's Avatar
A mild magnet is your friend when inspecting primered sheet metal.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-05-2017, 06:19 PM   #13
Clyde65
Clyde65's Avatar
Did you ask the seller or did you go see it and crawl under over and put your hands on it?
Clyde65
Rebuild of Clyde
support our troops!
Old 05-05-2017, 08:28 PM   #14
Cris
I looked at the CL ad and there is rust on this truck. Its just a matter of how bad. Heck the heater box and blower under the hood is heavily pitted.
Even in California they rust in the sensitive spots.
